Replacing LC500 torsen diff with LC500h one!
#121
breplica & anchaf3
Do either of you two guys have an idea of how long it took your installer to install the diff❓ My installer looked it up and says 15 hours I can't imagine it would take that long
Lou
Installation is pretty straightforward, the exhaust muffler section comes off, the driveshaft, rear axle, and rear steer module (if you have one) is disconnected and the differential is swapped. Everything goes back in the same way it came out. The LC500h differential housing is completely identical to the LC500. The differential/torsen is completely mechanical, there are no electronic elements to worry about. No error codes, no weird behaviour from the car. Everything feels stock, and works without issue.\
Lou
#122
2-3 hours tops for the install. If a guy tells you its 15 hours, find another mechanic
flowrider (09-09-24)
#125
breplica - Did yours come with a fluid filler cap? Mine came with a piece of green tap over the fill hole
Lou
Lou
#126
You can click on the part numbers on the diagram on this page and it will scroll to the part and show the part number https://www.amayama.com/en/genuine-c...0/chassis/4101
looks like the part number for the filler plug and filler gasket are 9034118032 and 1215710010. I need to go order these too now.
#129
was waiting for these last few parts to come in. New cushion mounts, upper stoppers, bolts and filler plugs and gasket. Dealership installing next week (mod friendly dealer). After whatever break in period, I Plan to do a full comparison on youtube with dragy times, data logging, mpg test, seeing what mph the 2 diffs max out at for each gear, and if needed going into the stock tune to change what mph the car shifts at when in auto. Then of course just ripping through the gears on both setups to hear how much different it is having to shift more often.
#130
I got mine installed this morning. breplica is correct; it's not a night and day difference. The regular driving feel is still the same. The car is more frisky. Neither I nor the LC is very good at drag starts. So, I did not measure 0-60. I did however, measure, with dragy, 60-100. Before the change I ran 6.25, after the change 5.95. My LC has a lightweight crank pulley, PPE headers, dual-mode exhaust, and lightweight Vossen wheels in addition to the new diff.
Lou
Lou
#133
Just got my car back the install was a success. I was told I have to take it easy for 1k miles so i’ll try to knock that out in a week so I can finish off the comparison youtube video. I went the route of dealership install for anyone wanting a rough estimate. I believe my dealership is 150 an hour. When buying the diff, the techs told me to buy an RC F “cushion mount” as well. Wasn't sure why until now. On the LC theres an unused hole on the passenger side for another cushion mount. (They did this on a previous LC not too long ago). So we replaced the small rubber dampener. Will post back when the vids done!
