Mark Levinson audio
#287
I tried the forums fixes on my vert and still having periodic bass distortion. Utah Lexus dealer is aware of it but not fix. I moved to Arizona last couple of months and will try their service once I take it in for service interval. I would hope they come up with a more standard fix.
#288
The ML sound system in the LC is average at best. I have the coupe and I too get occasional bass distortion. But I don't blame it all on the sound system. Some tracks are just recorded poorly and some are just beyond an accurate reproduction in the LC.
#289
No I inserted some insulation. I didn't want to modify it too much in case Lexus came out with a fix and tried to say they wouldn't replace since i modified it.
#290
That thick plastic plug is there to protect the subwoofer, not help the sound. And protect it from some considerable forces.
I hear you about not modding anything and sure respect that, but this is easy and it’s hard to imagine Lexus “fixing” this for years if ever.
RysLC500 (01-12-22)
#291
Well that does not work, removing the extra plastic is easy and no one would ever know unless you did accidentally punch a hole in it.
#292
Ok. I finally got around to cutting the plastic off of my subwoofer cover. It was not at all easy, but I was able to do it with no tragic mistakes. Owners of these cars should not have to do this. Lexus FIX THIS PLEASE!
#293
Before and after comparison? (And what tool did you use?)
#294
looks like some holes in it now.
#298
if someone with a coupe could figure out how to remove the cover!!!
#299
Imagine the courage needed for whoever was first to do this. We all owe a debt of gratitude.
ATLHeel350 (01-23-22)
#300
Thanks Man. I listened to the sound without the cover and knew it had to be done. It was not easy. But it is so worth it.
