Exhaust valves
Old 01-10-20 | 12:26 PM
  #46
pottypants's Avatar
pottypants
Lou,
not arguing the gains. headers & free flow cats ( or lack there of do a lot ,
but swapping those headers is special. im sure toyota had their reasons for reducing
the exhaust diameter at the back as well prob for sustained flow.
honestly id go the rear gear swap and prob get the same benefits.
5K is way to much for my blood for a few stainless exhaust pipes and i haven't
even priced headers or a tune.
sorry to derail thread
ppp
Old 01-10-20 | 12:44 PM
  #47
JoeJahja's Avatar
JoeJahja
Originally Posted by uchujin
From the pics I posted, it looks like the larger connector has 3 wires and the smaller one has 2 wires. I would guess 2 wires on the larger connector carry power to the valve motor (maybe one opens the valves and one closes them?), and the other is a shared ground. The smaller connector likely has one power and one ground. A multi-meter will confirm this. So one should be able to just cut the 4 ground wires - to break all 4 harness circuits. The 4 ground wires on the connector side can be spliced together and connected to one side of a switch. The 4 ground wires on the other side can be spliced together and connected to the other side of the switch. Done, right? Not so much...
The problem is - the system needs to be energized to open/close the valves. if the switch is open and you close it while the engine is running... The valves won't necessarily move until (A) the drive mode is changed, or (B) one of the vehicle dynamics trigger valve movement. Not such a big deal. However, if you open the circuit while the engine is running, the valves won't automatically fully open like they would when one turns the engine off. They will stay in the exact position they were in when you opened the switch. They need power to open.
This is my first posting and Thank you Uchujin for your thought, a couple of days I went to my mechanic and got the car lifted on a hoist. Dismantled the 2x plugs on each side completely and taped them. The sound was incredible when open up and put into manual. I then thought if I could get get a switch (like Active Exhaust) inside the cabin to control NORMAL or OPEN. I managed to buy through Ali Express a Remote Control switch with 4x channels (you can choose how many RC, I bought 3x). The Controller can be option for Temporary, Toggle or Latched. In our system, we need a Toggle. They cost only AUD$23. I will try to post the pic of the Controller here.
Joe
Old 01-10-20 | 12:54 PM
  #48
JoeJahja's Avatar
JoeJahja
Originally Posted by pottypants
Lou,
ppp
Thank you PPP, in the past I changed my CLS 500 DP, Rear Axle Exhaust and tuned the car. The output was incredible lifting the Torque from 600Nm to somewhere close to 800Nm, but the car was dangerously and nervously to drive. By spending over $10k for SS Exhaust and Tune, the car, the worst is the car stalled several times. For example it started the engine but will not able to put into DRIVE mode.
At the end, I swapped to AMG E43 but sound was not loud, not comfortable car to drive (suspension wise) and cannot be driven relaxedly. Hence LC500, other constraints is this time I like to keep the car as close to oem as possible, for Insurance purpose.
I still have another mod on Air Filter intake flaps on both sides to remain open all the time. This open up the sound even further. Let me know if anyone is interested. Cheers,
Joe
  #49
SuperGT's Avatar
SuperGT
Have fun experimenting, gotta root for those guys who just have to find out if they can make it work!!
The following 3 users liked this post by SuperGT:
FJRBob (01-15-22), guanche2k9 (01-11-20), JONPRON (01-11-20)
Old 01-21-20 | 02:57 PM
  #50
tiger1918's Avatar
tiger1918
Default Exhaust valves
Opened the exhaust. Now this car sounds fantastic. This is the way the factory should have made it. Car sounds great at ide and really good when accelerating. As stated 10 minute job
The following 3 users liked this post by tiger1918:
FJRBob (01-15-22), ISellHomes (12-07-20), mdamda (02-08-24)
Old 01-22-20 | 04:40 PM
  #51
asinow's Avatar
asinow
I dont know if anyone has posted a sound clip...Tiger1918 you started this so we elect you to do so!
Old 01-26-20 | 08:47 AM
  #52
North1Star's Avatar
North1Star
OMG the car sounds MUCH better now when cruising at low speeds! Thanks guys!
Whoever didnt do this adjustment yet, do it and you will love your LC more than anytime before
The following 2 users liked this post by North1Star:
ISellHomes (12-07-20), jennypenny (07-10-24)
Old 01-26-20 | 09:27 AM
  #53
SuperGT's Avatar
SuperGT
I think I was one of the 1st to try it back in June 2018. Did it as soon as I got back from picking it up new at the dealership. Went back with the valves connected two weeks later to do a proper before and after test. I can confirm that the difference is day and night at lower speed. Louder during acceleration, pops and occasional backfires when compression downshifting. It should of been set-up like this from the factory IMO.
Old 01-26-20 | 09:31 AM
  #54
pottypants's Avatar
pottypants
Originally Posted by SuperGT
I It should of been set-up like this from the factory IMO.
One of the reviewers commented on lexus engineers wanting the same loud sounds as the American V8s.
mgmt. at lexus came to an agreement, which is the current status of the exhaust with the valves.
The thing is you cant help but suspect the engineers had the default as open to allow people like us to disable.
Whatever the truth be told, im glad it ended up the way it is !
ppp
Old 01-26-20 | 10:30 AM
  #55
uchujin's Avatar
uchujin
I also did this early in 2018, but my experience was a bit different. I noticed no difference at all during acceleration in any drive mode. I suspect the valves are always fully open during acceleration to avoid backflow restriction issues. The only significant difference I recall was a louder tone during lower RPM driving. Although I liked the louder tone in Sport+ mode, I still prefer it being quieter in Normal and Comfort modes - especially when cruising with my more "well-adjusted" better half. I also wondered if the computer adjusts how lean or rich the fuel delivery is - depending on valve position. This could explain the more frequent "popping" experience. Anyway, time and user experience has shown no worrisome issues with this DIY modification - so I'm gonna try it again after winter hibernation ends. Another thing I like about this design is - the valves are not a muffler bypass, so it's never obnoxiously loud. It always sounds nicely-tuned, IMO.
Old 01-26-20 | 02:43 PM
  #56
OFTRASH's Avatar
OFTRASH
I unplugged all 4 when I seen this thread mainly because someone mentioned he/she was getting overrun. I love the sound and it's not harsh or over the top IMO. However, I have not experienced any overrun pops & crackles with this car before or after disconnecting. And was surprised the car didn't have it from the factory as most performance cars do.
Old 01-26-20 | 03:11 PM
  #57
uchujin's Avatar
uchujin
^^^ Same here. I only get occasional popping if I'm driving aggressively - typically in manual and Sport+ mode. opening and closing the throttle quickly as one would expect. I never get it if just cruising and keeping the RPMs well-below the redline. But I think that's just about right for a refined Lexus GT car.
Old 01-26-20 | 06:50 PM
  #58
flowrider's Avatar
flowrider
^^^^I've been waiting for some others to post, before I did. With my PPE Dual Mode Exhaust I also have no pops or crackles with my exhaust wide open. Those noises were common back in the day when engines were controlled mechanically. But, with the advent of electronic (computer) controls those noises are much rarer today. They would indicate unburned fuel down stream in the exhaust system.
Lou
Old 01-29-20 | 02:25 PM
  #59
flowrider's Avatar
flowrider
Attached is a cutaway of the mufflers PPE makes for their Dual Mode exhaust on the on the LC500:
Lou
pottypants (01-30-20)
Old 01-29-20 | 07:55 PM
  #60
SuperGT's Avatar
SuperGT
Can't speak for others but mine does exhibit some overrun, happens occasionally on compression downshifts without applying gas or brakes. I run all my vehicles exclusively on 94 octane without ethanol. Perhaps try that and report back.
