Tires
Old 12-21-21, 07:36 PM
  #286
fodalo
fodalo's Avatar
Folks I cannot remember. Can we use the larger 255 40 21 with the present 275 35 21 rears even though the O.D on the 255's are a littler larger? or do we need to increase the rears also? 295 35?
Thanks everyone!
Old 12-21-21, 09:03 PM
  #287
flowrider
flowrider's Avatar
Received 1,950 Likes on 1,373 Posts
^^^^Yes, 255/40/21 on the front stock 8½" wheels is fine. the stock 275/35/21 rear tires will work fine with the 255s in front. The rear 9½" rear wheels can go up to 285/35/21, but that size is hard to find.
295/35/21s are too wide for the stock 9½" wheel.
Old 12-22-21, 10:31 AM
  #288
fodalo
fodalo's Avatar
Thanks Lou!
so the front OD at 29 255's and the rear OD at 28.5. 275's are a go thanks much,I was rechecking because on the tires from Lexus, they have the OD front (245's) less than the OD (275's) on rears, the OD's was what I was concerned with with automatic track assist etc, did not want to send bad info to the computer and have it not right, hope all is well for you !! Merry Christmas
Old 01-08-22, 02:53 PM
  #289
Received 2,513 Likes on 1,652 Posts
so stock 21s are 245/40 and 275/35. much talk about 255/40 on front (although it seems non runflat 245/40 michelins do exist), but what about plus sizing the rear tires also to 285/35?
just thinking it might be nice to have a bit more rubber between the car and the road, plus to fill the wheel wells a bit better?
Old 01-08-22, 02:55 PM
  #290
here's an interesting tire, too...
CONTISPORTCONTACT 5 CONTISEAL
i'm guessing not a run flat, bit it self-seals punctures! thoughts?
https://www.tirerack.com/tires/tires...omCompare1=yes
Old 01-08-22, 04:23 PM
  #291
fodalo
fodalo's Avatar
Great tire company bitka. Been using them Conto All season Rad's on the Mrs X5 a few times around. Good product, no sure about this specific model.
Old 01-08-22, 04:24 PM
  #292
fodalo
fodalo's Avatar
Been using the Conti"s
Old 01-08-22, 05:36 PM
  #293
flowrider
flowrider's Avatar
My experience with Continental tire was horrendous
https://www.clublexus.com/forums/is-...xtreme-dw.html
Old 01-09-22, 05:52 PM
  #294
thanks. obviously that was a decade ago though and there's a load of different continental tires. but will keep in mind.
Old 02-07-22, 11:02 AM
  #295
crashxx
crashxx's Avatar
Default 21" All Seasons
For the love of God. Does anyone make high performance all seasons for our 21" wheels or will I have to buy some 20" wheels?
Old 02-07-22, 11:49 AM
  #296
flowrider
flowrider's Avatar
Sure - The Michelin PSAS4 will do fine. However the fronts will have to be upsized to 255/40/21 from the current 245/40/21. They will fit and work fine on the stock 21" wheels.
They are non RFT.
https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Sport+All+Season+4
Old 02-07-22, 12:10 PM
  #297
crashxx
crashxx's Avatar
Thank you sir!
Old 02-07-22, 12:44 PM
  #298
crashxx
crashxx's Avatar
I think I'll go with the Pilot Sport AS 4's. 255/40ZR21 up front and for the rear, is there any advantage going with a 285/40ZR21 over the 275/40ZR21?
Old 02-07-22, 01:47 PM
  #299
flowrider
flowrider's Avatar
The 285s will fit fine and add as bit more meat to the rear. Do you ever encounter snow? In snow a narrower tire is usually best. But there is not much difference between 275/285. If it were me, I'd go with the wider tire. However, you want 285/35/21, not 285/40/21.
Old 02-07-22, 01:49 PM
  #300
crashxx
crashxx's Avatar
Ok, I've corrected the size. We do get snow, but our cars do not see it. Thank you for the help!
Quick Reply: Tires
