Tires
#332
iam
Mich Pilot 4S are on B.O? Sorry to hear that. I went to the regular tire Mich P4 all season. serving us well. Left the Run Flats behind.
#333
finally found a set after calling about 30 shops around. It was the fronts I was having a hard time finding. Should be getting them installed next week along with my lowering springs and wheel spacers.
#334
Nice work Iam
#335
New owner here (as of 6/24) and I'm looking to get rid of the runflats that are currently on the car and swap them for Michelin PSAS4. I currently have the 20" wheels and the stock size 275/40/20 are on backorder until 7/29, but they have 285/35/20 that they can install right away. I like the extra width but the rear tire diameter is 0.8" smaller than stock, so I have a few questions/thoughts:
- Any concerns with this setup in the back?
- Will that height difference create any handling weirdness, since presumably that would drop the rear axle by 0.4"?
- I wonder if the wheel gap would change noticeably and look weird relative to the front.
#336
i wouldn't want tires that are nearly an inch smaller in diameter on the car because i think it will be visibly noticeable as 'small' in the wheel opening. backorder of the right size for a month is no big deal to me. i'd wait.
#337
https://www.tirerack.com/tires/tires...omCompare1=yes
#338
The smart move would be to continue to roll on the RF’s. Give yourself time to get a matched set of your preference. If you ever considered new wheels, that's an excellent reason to delay this purchase.
#339
wear the runflats out and like most of us, goto the conventional tire.
#340
I'm new to this forum; just bought a 2022 LC 500 convertible. I have a couple of comments/questions regarding the tire discussion.
My understanding is that once a RF tire is used without air pressure (running flat), it should be replaced regardless of where the puncture is located, if it was driven on for any distance. This is because, even though the tire allowed for limping home, it has been over stressed due to operating without air pressure support and may have suffered internal structural damage to the point of compromising safety. So, does anyone have experience with a Lexus dealership repairing a punctured RFT?
Regarding changing the tire OD for the front tires, wouldn't that affect the speedometer or possibly the electronic stability control?
Thank you, I'm already learning a lot on this forum.
#341
Don't think the dealer will ever repair a RF tire. Replace only.....I caught a nail in mine and plugged it myself even tho I wasn't supposed to. But in my case, tire never lost pressure and No subsequent problems with tire.
#342
My understanding is that once a RF tire is used without air pressure (running flat), it should be replaced regardless of where the puncture is located, if it was driven on for any distance. ...
#344
^^^^Answers to your questions:
Not Recommended:
https://www.tirerack.com/tires/tiret...jsp?techid=226
The most common upsized front tire size for the LC is from 245/40/21 to 255/40/21 - OD is 28.7" vs 29.0" or only 1% difference, so nothing to be concerned about. BTW I went with non RFTs very early in my LCs life. 295/35/21 and 255/40/21.
Not Recommended:
