LC500 spontaneous frame crack (or something else?)
#61
Not from what I've seen or gleaned but it does seem to be more common than you might think. It may be some owners of affected cars think it is or have been told it is "normal".
Probably worth watching this thread and see how much traction it gets which in itself might provide some clues.
#63
I have a feeling this will become more common due to the nature of the issue, which seems to be that over time the bolts will loosen, which causes the metal support brace to rub against the B pillar. As the vehicle shifts its weight, the panels shift against each other causing the clunking sound. And the fact that it's so close to the driver within the cabin makes it very noticeable.
I will ask the body shop to take pictures of the process.
#64
Im sure Lexus has already addressed this on newer model years to prevent it from happening as bolts should not be coming loose/welds breaking apart.
#66
I’m waiting on some more pictures from you guys before I take my convertible in for this fix. I’m pretty sure it’s the same problem.
is there a TSB on this ? Doesn’t matter which country or region but I’d be interested in seeing it.
I showed my dealership buddy that link from Lexus owners UK and he said unless they have a TSB they can follow it’ll take that much more time for the technicians to dig through all the threads and see if they can follow that same fix
#68
I agree, and an update would be useful. I'm not sure if the following thread and in particular details of one potential fix helps but this has been topical on the UK Lexus site:
https://www.lexusownersclub.co.uk/fo...lunking-noise/
In particular, look see the "TSB" posted by "Flytvr". When that approach isn't successful, or it fails, then it is necessary to have the brace welded, problem solved.
#69
Are there any in-car photos of something doing this DIY? It looks to me like a structural adhesive (bond prep the surfaces, no paint, no contamination, and apply some JB Weld) would be a easier solution than welding it to the chassis. No?
#70
#71
@Brinylon posted a link above that shows how a tech should repair the problems without welding, but it doesn't show the steps needed to access the area in question so it's not 100% complete. However, it's pretty close.
I'm taking mine in next month and will try to learn more about the process since I'm concerned that re-greasing and re-tightening the bolts may not be a lasting solution and I don't want to pay another $1k to fix it again if the first fix doesn't work.
#72
I'm not familiar with this fix, but, I probably wouldn't be concerned if they were to use a quality grease, and use Locktite on the bolt threads.
#73
#74
Unfortunately joining the club of the cracking frames 🥲 with my LC500H.
My underground parking ramp is very difficult and I believe this is the cause of the cracking.
will take it to the dealer soon for them to check.
#75
I wouldn't call it a crack, it's more akin to looseness or body flex. I'm really looking forward to reading feedback from some/anyone who has taken their car in for investigation, and at the same time I hope the problem is readily resolved.
