Paddle shifters
Old 09-07-21 | 02:28 PM
Ferraribob's Avatar
Ferraribob
Default Paddle shifters
Question, when I have my car in manual mode and I'm at a complete stop, if I floor the car when it hits redline it shifts into the next gear. Is this normal? If I do the same thing in my Ferrari the car will not shift into the next gear no matter what. Bounces off the Rev. Limiter and u have to shift. Thanks
Old 09-07-21 | 02:39 PM
Ferraribob's Avatar
Ferraribob
Question, on manual mode using paddle shifters my car will shift itself from 1st gear to 2nd gear. This happens from a dead stop using manual mode and paddle shifters. On my Ferrari, it will hold the gear no matter what. It let's you know real quick when it hits the Rev. Limiter. Is this normal?
Old 09-07-21 | 03:25 PM
welcome ferraribob. i merged both threads into 1 as they're the same topic.
Old 09-08-21 | 01:51 PM
74Sprtstr's Avatar
74Sprtstr
Red face
sure enough, bob, your lexi is smart enough to shift itself, to protect itself
The following 2 users liked this post by 74Sprtstr:
Exhilr8n (09-09-21), raider888 (09-15-21)
Old 09-08-21 | 05:29 PM
guanche2k9's Avatar
guanche2k9
I'm not sure if that's the case. I know mine will bounce off the rev limiter. Now I have to double check if it does it off of 1st into 2nd (meaning bouncing off of 1st gear) or will only do it once I go into the higher gears.
Old 09-08-21 | 06:02 PM
Ferraribob's Avatar
Ferraribob
Maybe I'm getting old, but I swear this car always held first gear no matter what. If u held first gear to red line it would bounce off Rev limiter and would not shift until you went into second gear.. Now as stated above, it will shift itself from first gear to second gear automatically In manual mode.
Old 09-08-21 | 06:43 PM
74Sprtstr's Avatar
74Sprtstr
Talking
Originally Posted by guanche2k9
I'm not sure if that's the case..
you may not be sure thats the case, but in fact, that is the case, from p 160 of the owner's manual; the next word is "... engine..."
asinow (09-14-21), guanche2k9 (09-09-21)
Old 09-08-21 | 06:46 PM
74Sprtstr's Avatar
74Sprtstr
so our little lexis are programmed to take care of themselves. lets see, no flat tires, cant hit something dead ahead, warns me when i'm too close:
what more could an old guy ask for ? damn it, my little lexi takes good care of me too !
raider888 (09-10-21)
Old 09-08-21 | 09:59 PM
just wondering why you want to thrash the car in 1st gear, banging off the rev limiter repeatedly?
Old 09-09-21 | 12:52 PM
Ninja400's Avatar
Ninja400
The LC500 reviews on YouTube by SavageGeese and TheStraightPipes show that the car will let you bounce off the rev limiter - so it's definitely possible to do that. Perhaps that logic is controlled by the mode you're in? In comfort/eco mode it'll auto upshift, and in sport/S+ it'll hold gear? Just a guess.
As for why you would want to do it... hitting the rev limiter for a split second before shifting does sound pretty nice in this car, as demonstrated in those videos.
Old 09-09-21 | 03:41 PM
i hate that sound. would never do it.
Old 09-10-21 | 02:02 PM
74Sprtstr's Avatar
74Sprtstr
what is that sound, actually ? kind of clatters; is it canned, is it compression bleeding off a bleeder - sounds like a jammed .50 cal ....
Old 09-10-21 | 02:10 PM
assume it's just because the fuel is being cut off to the cylinders causing misfires and exhaust burbles.
Old 09-10-21 | 02:14 PM
DRGibbons's Avatar
DRGibbons
It is the ECU shutting off spark to the plugs and/or injectors to not allow the engine to rev higher than the programmed limit.
Old 09-11-21 | 08:21 PM
Exhilr8n's Avatar
Exhilr8n
It is a very unnatural sound to experience.
Have you been in cars with Launch control? Some sound very similar to the overrev cutoff, probably hold the rpm at a constant level by similarly retarding spark.
A lot of theatre to experience when that rev limiter holds it until you release the beast.
