View Poll Results: What kind of engine oil are you running in your LC 500?
Conventional
30.30%
Synthetic
23
69.70%
Voters: 33. You may not vote on this poll
Oil
Old 06-13-22, 12:33 PM
  #31
JSM701
JSM701's Avatar
Originally Posted by sickpuppy
I'm sorry, but IMO, you are interrupting it wrong. It states:
There is an OR in their recommendation. Believe what you wish, but in my mind newer technology is better. Just a question here - Where have you heard that synthetic oil may be detrimental for an ICE?
This will be my last post to this thread. Arguing this issue is simply a waste of my time.
Arguing with you is a waste of my time too.I will follow Lexus recomendation on this subject.After viewing your other posts your always right on subjects you have not researched. Also my last post to this thread.
JSM701 is offline
The following 2 users liked this post by JSM701:
bitkahuna (10-05-22), TripFarmer (06-15-22)
Old 06-13-22, 12:53 PM
  #32
DRGibbons
DRGibbons's Avatar
You can lead a horse to the water but you can't make him drink!
Adios Amigo!
DRGibbons is offline
Old 06-13-22, 01:07 PM
  #33
JSM701
JSM701's Avatar
Adios Amigo!
Keep your remarks to yourself. Amigo
JSM701 is offline
Old 06-13-22, 02:11 PM
  #34
Received 2,458 Likes on 1,612 Posts
merged two related threads.
folks, be nice.
bitkahuna is offline
The following 2 users liked this post by bitkahuna:
355F1 (06-13-22), DRGibbons (06-13-22)
Old 06-27-22, 09:03 PM
  #35
SunCruzin
SunCruzin's Avatar
Those 'several Lexus dealerships' were wrong. Just saying.
Use what you wish. Conventional oil will not harm the engine and if you strictly follow a proper oil and filter change regimen your engine will last like a Lexus - but there are products out there that are better.
Also bear in mind, as Lou points out, oil technology evolves and oils get better. The fellow that strictly follows his 1957 Chevy's owner's manual recommendations is most certainly not doing his engine any favors (granted - extreme example)
I finally followed up with the service department today and one of their master technicians. He stated, that yes, you can use synthetic oil for the oil changes in the LC, and as mentioned here before, just do not extend the change interval. The service department had initially misinformed me. I will keep the conventional oil in place until the next oil change at which time I will be swapping it out for the synthetic.
SunCruzin is offline
The following 2 users liked this post by SunCruzin:
355F1 (06-28-22), DRGibbons (10-01-22)
Old 06-28-22, 06:17 AM
  #36
MLMLC52K18
MLMLC52K18's Avatar
'Live Long & Prosper'
MLMLC52K18 is offline
SunCruzin (06-28-22)
Old 09-29-22, 02:57 PM
  #37
ChicagoRJ
ChicagoRJ's Avatar
So, it's obvious lexus wanted to use conventional and that is what they put in the LC, even though many of their other vehicles come with synthetic. Seems odd, but whatever.
What brand of synthetic are most using for their LC ???
ChicagoRJ is offline
Old 09-29-22, 07:20 PM
  #38
fodalo
fodalo's Avatar
For $89.95 and conventional oil per the service manual, I will continue to do what the factory suggests. Ya think they know best?
fodalo is offline
JSM701 (09-30-22)
Old 10-05-22, 12:49 PM
  #39
ChicagoRJ
ChicagoRJ's Avatar
Well, technically, they are the ones who "invented' the touchpad for the LC500, no ? So, no, they are not always right. LOL
The following 2 users liked this post by ChicagoRJ:
bitkahuna (10-05-22), DRGibbons (10-05-22)
Old 10-05-22, 02:08 PM
  #40
car oil is like religion to so many... lots of arguments and in the end it makes NO difference.*
* as long as they actually change the oil at reasonable intervals with fresh oil.
Old 10-06-22, 10:45 AM
  #41
fodalo
fodalo's Avatar
So what do touch pads have to do with oil? Knowing whats best for an engine with millions of test miles??? LOL!
fodalo is offline
Old 10-06-22, 10:52 AM
  #42
fodalo
fodalo's Avatar
No reason for the LOL RJ, sorry for that.
fodalo is offline
Old 10-06-22, 11:59 AM
  #43
Veight
Veight's Avatar
The mystery to me is why Lexus recommends conventional oil but no one at Lexus seems to have a valid reason why. I have heard that at break-in that synthetic oil is actually too slippery to allow the piston rings to seat properly. But why isn’t that true on all engines. Why just the V8. And why after break-in is over, does Lexus still recommend (service managers at my Lexus dealer and others I have heard about on here) conventional oil after break in?
I have no problem spending a bit more for synthetic on a $100,000 car every 5,000 miles. And the key as everyone has mentioned is not going over 5,000 miles before a change.
This You Tube video I believe shows exactly why you should not go over 5,000 miles on an oil change. It’s long but interesting.
Veight is offline
Old 10-07-22, 08:32 AM
  #44
fodalo
fodalo's Avatar
Thanks Veight! Must be someone out there that knows!
fodalo is offline
Old 10-07-22, 12:59 PM
  #45
RiotGrip
8th Gear
RiotGrip's Avatar
https://youtu.be/TJhFAwFv-O0
I suspect Lexus simply acknowledges that conventional oil is fine in their naturally aspirated V8. I'll give you my reasons why it may be OK in the LC500, but maybe not OK in other models. I doubt they are saying "don't use synthetic".
1. A V8 with a 7k redline would do better with a 30wt oil than a 20wt which is recommended for almost every other toyota engine.
2. Most other toyotas recommend 0w-20 which is only available in synthetic.
3. The LC 500 won't even let you redline the car until the oil is at a certain temperature, modern conventional 30wt oil at operating temperature is gonna protect as well as synthetic in almost all scenarios, you only see the benefits at really hot or cold operating temps or long drains. The driver with no track time and a 5000 mile oil change interval is putting very little stress on their oil--even if it's conventional
4. The LC500 has a 9.1qt sump! That is a large amount of oil for a 5L engine--more additives, harder to be starved of lubrication. Again, no sweat for a modern conventional in almost all scenarios. Especially considering most other lexus models probably take 5qts or less.
That being said, I change my own oil and filter and I use Quaker state Ultimate durability. It's a low cost synthetic option that is good when I do drive my LC in the winter and its cost is only about 2-3$ more than conventional for a 5qt jug. I can change my own oil and filter for about $58(not counting the money I spent on low profile ramps so that I can get under the car lol). I did the first oil change at 5k with conventional oil and switched after that. I'll agree its silly to spend 100K+ on a performance oriented car but put dino oil in it. However conventional oil is so good these days that my rational side knows that it won't make a difference for almost any driver at 9.1qts and 5000 mile interval.
RiotGrip is offline
Quick Reply: Oil
