View Poll Results: What kind of engine oil are you running in your LC 500?
Conventional
30.30%
Synthetic
23
69.70%
Voters: 33. You may not vote on this poll
Oil
#62
Because you stated "they know best". Well, the folks/engineers/whatever don't always know best. We all know the stupid touch pad has come to their attention 4 years ago and still done nothing about it. So, "they" are not always right, and when they are wrong, they dig in and won't change. I just wonder if that is going on with the oil as well.
#64
^^^ post of the day
100% agreed on all points... car is not being driven like a formula 1 race car.
i've only had 1 oil change so far (free, at dealer, and they put in synthetic ) so haven't had a need to change it on my own yet. but i likely will when it comes time (after next change). i've done it on some of my other vehicles.
how hard do you find changing the oil on the LC?
i've used a fumoto drain plug/valve on other cars because it makes draining the oil so much easier and not messy. recommended.
What I find a little confusing about this discussion, is that the badge under the hood only says 5W30, and nowhere in the manual does it say, you need to use conventional oil.
I believe, the manual would state that only conventional oil should be utilized if it was a mandatory requirement. It does say, that the oil that is being placed into the engine, needs to be a certain weight as well as meeting certain quality specifications. Whether the oil is synthetic or conventional as long as it meets or surpasses the denoted requirements, either really should be fine. Further, as I posted awhile ago, a master technician at Lexus advised me that one could absolutely use synthetic oil in an LC. I feel, it is a personal preference. I use synthetic in my LC, and believe it is the best way to go for protecting the engine and that offers me a little bit more peace of mind.
The point is that Lexus service recommends conventional and the new car comes with conventional. No one said the label in the engine bay says conventional oil required.
I may convert to synthetic after I hit 10,000 miles.
The other issue is that if you look at the You Tube video, is you don’t know what oil the Lexus dealer actually uses. They buy the cheapest bulk oil possible and self oil changes is the only way of actually knowing what brand of oil you get. Regardless of the conventional/synthetic issue.
i think the oil brand is actually a bigger issue than if the oil is synthetic or not. With a dealer you don’t know what you are getting.
When I had my BMW 550 and my BMW dealer was changing the oil I am certain they were not changing the filter for several changes. When I went to do my first self oil change the filter was extremely dirty and crushed from over use. Can’t prove it but I’m certain they skipped changing my filter and this was a high end BMW dealer.
I hate letting anyone mess with my car unless I’m watching.
This discussion seems to be centered around whether synthetic or conventional oil is better, and which is the best to go inside our LCs engines. The service department initially said that I needed to put conventional in at my first oil change, and when pressed on it, they reversed their information.
A number of people who posted here were convinced that we absolutely needed to use conventional, and this was a big part of this particular thread's discussion. I may have missed this somewhere within the posts, but how do we know that the engine comes from the factory with conventional?
Is Lexus recommending different viscosity oils depending on climate? All I saw was that 10w-30 could be used if that’s all that was available but needed to be replaced at the next service. Looks like Lexus recommends 5w-30 for all climates. Synthetic vs Conventional is one thing, but changing viscosity is a whole lot more significant in my view.
bitkahuna (10-10-22)
#65
RJ you sound intelligent, you may want to write the factory.
#67
I know that I am a lil late to the discussion…But my most important take-aways are that:
****Some Dealers just can’t be trusted to provide all the services you pay em for.
****You really don’t know what kinda oil they’re putting into your car.
****If you want 'oil change' done Right, best to do it yourself.
RiotGrip (10-11-22)
#68
I have the same mechanic everytime I have had the car serviced ( per my request) and he has come out to talk with me a few times. 23 yrs at the ship and he is reliable and top notch oer the lexus team. $83.00, conventional oil change 2wks ago. Get to know those u incorporate to do your work.
#69
Low mileage use
I drive my LC in summer only for a total of 3,000 miles per year. Would you still use the 5,000 mileage interval for oil changes or simply change the oil once per year at the beginning of each summer season, regardless of mileage.
#70
I recommend adhering to an oil change every 5,000 miles or yearly.
#72
RJ thanks for your reply. I would think that an educated man like yourself would come up with some better verbage to describe someone you've never met. I will be praying for you in the hopes that your choices in the future will be a little more encouraging.
