Scrape Armour
Old 01-14-23, 06:39 PM
Ephilyaw
Ephilyaw's Avatar
Default Scrape Armour
Just installed Scrap Armor (this should have been factory). Leaving work 2nd day of ownership got a small scrap - UGH. Ordered Scrap Armor that night.
I installed it myself - pretty straight forward.
First install the left and right pieces before the center piece. The left and Right pieces start near the tire using one existing bolt (only one - all else are drilled). Be sure to tuck the first pieces under the underbelly of the car before adding the bolt. Then drilled from tire to center. No need to install bolts but a few turns as you need to leave them loose enough to leave a 1/4” gab for the silicone.
After all screws in for left and right then center the center piece perfectly and install its bolts. There is a line that will one up perfectly for the center to the left right (pictured below). Before staring the silicone, uninstall the far left and far right screw of the center piece. You need to do this so you can silicone the left and right piece all the way. Have everything ready before staring the silicone. Like plenty of shop disposable towels to wipe excess. Silicone the left and the then right side. Than the center. Install the 2 bolts removed for the center. Tighten all screws. Spray the silicone and clean it up. I used my finger (much better than the scrapper) - I may loose my finger, but worth the sacrifice for the LC. After all is smooth be sure it has 100% coverage and no gaps. If if does, be sure to cover those areas.
Now enjoy with a little
Very hard to see from any angle
Center piece lines up with the left and right pieces
less stress.
Feel free to ask any more questions - I am way into the bourbon and may have left off stuff.
The following 2 users liked this post by Ephilyaw:
LC500Dan (12-29-23), StuM (01-12-24)
Old 01-14-23, 06:40 PM
Ephilyaw
Ephilyaw's Avatar
LOL Scrap Armor
Scrape Armor
Again Bourbon
Old 01-15-23, 05:24 AM
CJinTx
CJinTx's Avatar
Nice install!
Old 01-15-23, 05:58 AM
JDTinTexas
6th Gear
JDTinTexas's Avatar
Agree with CJ. That came out nice!
Old 01-15-23, 09:50 AM
Badhobz
Badhobz's Avatar
Originally Posted by Ephilyaw
Does the armor go to the leading edge of the front lip? especially from the last picture, it looks like it doesn't. That leading edge part is where i got a few nicks in my maserati before and would be my biggest concern.
Also it screws into the bumper right? if you end up removing it for whatever reason (maybe you want to install a bodykit), doesnt the bottom of the bumper have a lot of these small screw holes?
Agree with the rest of the gents that it looks great!
Old 01-15-23, 09:54 AM
Ephilyaw
Ephilyaw's Avatar
It does not cover the leading edge that is angled down to the bottom. It starts at the bottom flat surface of the car. If you ever remove it - you would have holes in the plastic bumper.
Badhobz (01-15-23)
Old 01-15-23, 10:26 AM
Badhobz
Badhobz's Avatar
I think that angled down part is where you could potentially get some scratches on steep driveways etc.
Old 01-16-23, 04:58 AM
Beachtyme
Beachtyme's Avatar
Looks good, nice install.
Old 01-16-23, 11:22 AM
Received 2,458 Likes on 1,612 Posts
looks great, but i can't follow your install instructions at all.
Old 01-16-23, 06:47 PM
Ephilyaw
Ephilyaw's Avatar
Your tube has plenty of videos - sorry. Was well in to the bourbon when I loaded pics
bitkahuna (01-17-23)
Old 01-17-23, 03:56 AM
MLMLC52K18
MLMLC52K18's Avatar
Anytime you drill holes to attach anything (whether functional improvement or not) to the body of your car, dealers treat as a negative impact on vehicle value. My LC is my forever car so I would never be concerned with that issue.
Old 01-17-23, 10:53 AM
DaddyFES
DaddyFES's Avatar
I just park far enough from the curb that it looks like I drank bourbon.
The following 2 users liked this post by DaddyFES:
BruceinFla (01-18-23), CJinTx (01-17-23)
Old 12-29-23, 08:35 AM
LC500Dan
LC500Dan's Avatar
Just had Scrape Armor installed on my new-to-me 2022 LC inspiration by the body shop repairing the front bumper from prior owner (or dealerships) scraping the he!! out of the entire undersurface. Bodyshop did amazing repair and repaint then installed the Scrape Armor just as you did. Looks great and hard to see it unless under the car as you said. You're right, it should be factory given the low front ground clearance. Combined with my front camera install, should help a lot. Agree that it would be nice if it lipped up a little on the leading edge for some front protection, too.
Dukeaudio (12-29-23)
Old 01-12-24, 09:21 AM
tecman
tecman's Avatar
Hey @Ephilyaw it has been a year since you installed the Scrape Armor. How is it holding up? This and the universal fit SLiPLO are the only options I am finding. The Scrape Armor seems like a better choice to help even out the possible impact of road debris along with better coverage for scrape protection. I would rather have something screwed in than stuck on anyway.
I know it has been a short time @LC500Dan any input you have or anyone else that has this?
Thanks
StuM (01-12-24)
Old 01-12-24, 10:01 AM
Ephilyaw
Ephilyaw's Avatar
I have had Scrap Armour one whole year - luckily I have had zero scraps as I am very careful.
As far as the mounting, it appears to look the same as the day I installed it. I would do it again for the security.
StuM (01-12-24), tecman (01-12-24)
Quick Reply: Scrape Armour
