Lexotic Concepts A Reflection of Perfection.
SRT Stage 4 Turbo w/N2O WRITE UP
Old 11-20-02, 04:10 AM
hov
hov's Avatar
this is an auto?, or did they swap the transmission?
hov is offline
Old 11-20-02, 04:15 AM
JAC JZS
JAC JZS's Avatar
He is using the stock auto tranny, but I think when his power increases he is going to have a heavy duty racing tranny installed(built/ fortified auto).
JAC JZS is offline
Old 11-20-02, 08:06 AM
Sentinel
Sentinel's Avatar
Default HAHHA
Your post on .net has vanished.
Sentinel is offline
Old 11-20-02, 09:50 AM
isman
isman's Avatar
Originally posted by jpa2400
So your at 463 now. Add some more parts your waiting on, tune some more and add your N20, what is your RWHP goal here? Awesome car!!
Thanks everyone for the compliments, the 463rwhp was achieved on 3rd gear. Our 1:1 gear ratio is 4th, so the hp# could have been higher. I have a 3" custom exhaust, but the muffler is Greddy and is a bit restrictive (less than 3"). I've already ordered a 80mm (3.1") Blitz NurSpec muffler. It should give me another 10-15whp more. Thus, with the new muffler and on 4th gear, It should dyno around 480whp. If I use full C-16, we estimate over 500+whp easily at about 22psi, but we didn't want to do that yet. The tranny needs to be built. I'm on stock tranny with just a valve body upgrade. The tranny is in working progress as we speak . I will be taking more vids. of some tire smoking, dounut making, WOT drive-by shots very soon. Will keep everyone up to date.
isman is offline
Old 11-20-02, 09:59 AM
isman
isman's Avatar
Originally posted by ThomsonCharm
You are doing this all with 440 cc injectors? I was just wondering because from my experience you wouldnt be able to go over the rating on the injectors as far as rwhp without screwin something up. Atleast not on pump gas. Or did you run pump gas on the dyno when you did that? Just lettin you know for your injectors this application seems a little extreme and you might want to step up a size.
Later,
Good observation Thomson. At this period in time the 440cc H.I. injectors are the biggest there is for the IS300, until you go stand alone (w/Haltec will be using 720cc). I'm maxed out on hp on pump gas . But at this stage in my car, the max whp on pump gas is in parallel to the amt. of hp that my tranny can handle so it's fine. As soon as the tranny upgrade is done, C-16 or Cam2 would be used more often, and Haltec and full internals are on sched. of projects after end of next season. My A/F is fine through out the entire rpm range 12:1 . Thanks for your concern and advice.
isman is offline
Old 11-20-02, 12:00 PM
J.P.
J.P.'s Avatar
So in your mind, when your all said and done, where so you plan to be with the rwhp? 600?
J.P. is offline
Old 11-20-02, 12:52 PM
DrRick
DrRick's Avatar
every time that i try and watch the vids it downloads and then i get a broken piece of film. i know that this normally means that the player is broken. but i can watch other things with it. is it me or the vids.......
Doc
btw, bad *** car, bruh.
DrRick is offline
Old 11-20-02, 01:30 PM
isman
isman's Avatar
Well, when I'm finally finished (which would be never), by the end of next season about this time of the year, full internals, blueprint & balance engine, race built tranny, bullet-proof the rear, and with stand alone (most likely Haltec), the rwhp would be around 750rwhp. Then I would stop. (no sense doing more for me-even at over 450whp it's scary). Hey DrRick, just right click and save. Enjoy the vids.
isman is offline
Old 11-20-02, 02:02 PM
J.P.
J.P.'s Avatar
So 750 whp on a 2jz-ge? Very nice
J.P. is offline
Old 11-20-02, 02:51 PM
JAC JZS
JAC JZS's Avatar
Yeah that is nice, here is a link to a 2JZ-GE, NA-T(same as isman), that has about 800RWHP(without NOS). He ran 9.98@137 in the 1320.
http://www.supraforums.com/showthrea...threadid=45230
JAC JZS is offline
Old 11-20-02, 03:36 PM
isman
isman's Avatar
Wow :eek: that is crazy. I can't even imagine breaking 11's into 10's. Sheesh, well, that's next year.
isman is offline
Old 11-20-02, 05:47 PM
JAC JZS
JAC JZS's Avatar
Yeah really shows the potential of the 2JZ-GE.
JAC JZS is offline
Old 11-20-02, 11:42 PM
isman
isman's Avatar
Just curious. JAC JZS your sig. shows all your cars being sold, so what kind of car are you driving now?
isman is offline
Old 11-21-02, 02:23 AM
JAC JZS
JAC JZS's Avatar
It changes regularly but at the moment nothing...well for me nothing('01 Mazda B3000 Pickup, Toyota Camry)... looking for some new stuff though ... as soon as some W211 E55's hit the auctions I'll be getting one of those.
JAC JZS is offline
Old 11-21-02, 12:47 PM
IS200 3SGTE
IS200 3SGTE's Avatar
Hey
ISMAN awesome job, your car is amazing and much handle like a animal! (i like drag racing but road racing is in my blood).
Also if you really want to look at the true potential of the 2JZ-GTE you have to look at Import drag racing in the Pro class, built 2JZ-GTEs can push upwards of 1400HP (grant downings tundra with a built 2JZ dynoed at 1200HP before the wheels started to spin on the dyno, the engine is good for 1350+HP).
Or look to the street tire class the Titan Motorsports car has been dynoed at 1115HP or the other many 800+HP Supras.
Isman your 2JZ should handle that 750HP pretty well! make you take lots of picks and video as the build up goes on!
keep up the good work.
IS200 3SGTE is offline
Quick Reply: SRT Stage 4 Turbo w/N2O WRITE UP
