How to fix rain leaking into amp area
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
I have a 95 sc, and I have the problem that the stereo is very faint/does not work at all when it is raining. I did some searching and found this thread:
https://www.clublexus.com/forums/sho...light=rain+amp
But it didn't show how to cure the problem. Does anybody know exactly where the water comes from so I can fix this? I hate driving with no music
Thanks,
Zac
Thanks,
Zac
Like that thread says, rain may be getting in through the trunk weatherstripping. You can replace the stock weatherstripping, add some extra home-depot weatherstripping, bend/remount the trunk lid or add a bead of RTV silicone to improve the seal.
Keep in mind the sunroof area drains through a hose that runs down the c-pillar and is supposed to drain through a grommeted hole in the bottom of the amp area. Be sure that hose is clear and is routed out the car.
glad to help with more info. there are 2 more places that could be leaking.the right tailite gasket and there is a gasket under the black plastic airbox below the amp in the bottom of the right quarterpanel. i would seal them with waterproof gasket compound.
