Subs in Trunk?
OK I got a question about putting my subs in the lexus.
With the gas tankbeing in between the trunk and the compartment is that going to kill the bass making it to me. Any suggestions opinions or experience with this. Is a free air sub in the old factory location better.
( I hate free air subs )
Let me know thanks.
Let me know thanks.
I'm not a fan of free-airs, either... you can get a high-power 10" sub, drop it into the factory location, and glass a box behind it (very difficult), or jus take the factory sub out, letting more air/bass through from the trunk into the cabin. Also, if you take out your back seat, there is a little round plate the covers the fuel access lid (for lack of a better term). You can take that out, and that will let even more air in - not sure if that plate is there for a reason other than separating the cab from the trunk, so you might want to look into that, first.
That little plate DOES let more bass in, but if you get in a wreck, it would me more likely for your car to explode, or something along those lines. I didnt take mine out. I have 2 12" subs in my trunk, i have enough room for about 3-4 backpacks, and thats it. I wish I had more trunk space, but it hits hard enough for me. I don't have my stock sub in, I took that out when they were installed. The thing that kills the bass is that it has to go through the firewall, through the gas tank, through another firewall, through the back seats, then it gets to you. If you put the windows down, or even the sunroof down, it makes a big difference in SPL and SQ. I think its worth it though, setting off car alarms and having a really nice back massage whenever you want. The free air sub, i'm pretty sure, cannot do that, or as easily.
-Richard
-Richard
If you'll do a search, you'll see lots of examples of woofer enclosures in the SC trunk.
The hole created by the removal of the stock woofer is plenty big, there should be no need to remove the "fuel access lid " (which is there to allow access to the in-tank fuel pump). The pump is in the tank to allow full pressurization of the entire fuel line, eliminating vapor lock.
-Richard
-Richard
Perry, why did you mention the fuel pump and vapor lock? Jus wondering...
Originally posted by RSTSpeed
not sure if that plate is there for a reason other than separating the cab from the trunk....
heyarms
08-07-12 08:11 PM
en11871
19
03-16-08 10:04 PM
Rock-a-Lex
02-22-08 07:57 AM
ummagawd
06-03-05 11:35 AM
