Some Pics Of Install So Far
HERE ARE SOME OICTURES OF WHATS BEEEN DONE SO FAR WILL POST SOME MORE OF PS2 INSTALL HAVE NOT HAD A CHANCE TO TAKE PICTURES OF THAT YET..
Re: concentrate!
Originally posted by darden
if you stare at the screen long enough, you eventually will see something strange.
PROBLEMS
WELL JUST CANT FIGURE OUT HOW TO POST THESE PIC IF I COULD GET SOME HELP WOULD LOVE TO SHOW THEM TO YOU SO SOMEONE HELP IF POSSIBLE. THANKS
First, TURN OFF CAPS unless you are yelling.
Second, select "Post Reply"
Third, look for where it says "Attach File" and click the Browse button.
Fourth, find the file location and select the filename of the picture that you want to post.
The file should be in jpg, bmp or other standard file type.
File size is limited to 100k so make sure it is not too high a res pic, otherwise you need to use Photoshop to reduce the resolution .
That's it.
That's it.
