stock pioneer amp
YES!
But they're hard to get to...
Are you an electronics guy? TecKis300 and I found solder points to get line level information. Post processing, meaning, we couldn't find full range front/rear (though they are probably there...) but we did find crossed front/rear with sub output (5 outputs total +1 for SGND).
Hopefully BananaGS will confirm (second attempt) sometime over the holidays, with a write up to follow.
Tim
Tim
Thanks, but I was actually, I was talking about RCA line outs, where I could just plug rca plugs from the stock amp into a aftermarket amp, and just hook up the speaker wires from there. So I guess there are no RCA line outs from the pioneer amp. Would you happen to know if there are DIN plugs with RCA jacks, which would mate with the connectors from the stock head unit?
Not sure what system you have...but CD switching is done internal to the amp (has its benefits) instead of in the head unit...there are no easy solutions. There are line level outputs, but you have to add your own RCA's, just like the amp.
We had to solder wires, with RCA ends to the PCB of the amp to get line level info. You can probably use a switch before the amp to add aux input to the system (on the CD signal wires)??? This is my next project.
Sorry. Nothing is easy...
Tim
Tim
Tim
Tim
why cant you just take the wires from the amp that lead to the sub and use a line level converter to turn them into RCA's?? But then again, maybe I am just missing the whole point here?
Originally posted by rjheard
So does this mean that if I use an aftermarket amp with input out of the headunit before the factory amp I will not be able to select between my CD/Radio as I do now? Do you have a diagram or location of the connections you soldered the RCA's to.
If you hook up an amp, to the line outs of the OEM HU, you will be able to switch between AM/FM and Tape, using your amp, but you will not get a signal from the CD.
Tim
He wanted line level outputs, and was wondering if they came anywhere in the factory system...
Tim
johnsc400
01-10-03 07:26 PM
