CD Player gone quite ?!??
Hey Guys,
Got in my 93 LS today and flipped over to CD and didn't hear anything although I could see the track playing in the LCD. thought it was strange so I flipped back to FM and everything works fine. Flipped back and again no sound coming from the CD Player. After playing around with it (changing out CDs) I noticed I could barely hear the CD player if I turned the volume to full blast.
Anyone heard of this of this problem?? Is there a fuse in the CD player itself? Does the CD player have a built in amp and maybe it has died?
All equipment is original and hasn't been altered, and I don't think I have ever even had the volume more than 1/2 way.
Really wierd... I can see it going out but the dam thing is playing and I can barely hear it when the volume is maxed out so it is still working in a way?!?!
thanks for the helps!!
It sounds like it either needs to be cleaned or the laser has worn out. Unfortunately CD players do wear out after a while , your car is more than 10 years old so it wouldn't surprise me. At least your radio still works.
I will try cleaning the lazer tommorow. I have done that a few times in the past but when the lazer is dirty is usually just skips a little especially when I hit a few bumps in the road.
This is so weird. Radio works fine and the CD Player is playing just no volume until I turn it all the way to MAX and then I can hear the CD playing but very quitely.
Wish I could get some more input from others here. Is it possible the AMP went out or blew a fuse in the CD player? But the volume works fine when in Radio mode?!
I don't know enough about the stock CD player (panasonic) to even quess at it.
I cleaned the CD Player today with one of those cleaning CD's. Didn't fix the problem. Still no sound unless I turn the volume full blast, although the Radio works just fine?!?!?!
Are there any fuses in the CD Player box itself? Is there a built in amp? WTF.....
if you can hear the music at a low coming from the cd changer then a new pcb board with the amp chip will do the trick.the cdx-m8036zt cd changer you have is one of the best ever made and worth fixing. its the pcb board with cnp2714 marked on the circuit board. the board is not any harder to remove then a new discs drive in a computer.a new one is around 100.00. better to get a whole new board then just trying to fix the chip gone bad.
SPX,YES THE BOARD IS INSIDE THE CHANGER IN THE TRUNK. SEND ME PM WITH YOUR EMAIL ADDRESS AND I WILL SEND PICTURES OF THE BOARD. THE CHIP THAT PROBABLY HAS GONE BAD IS CALLED THE "4 CHANNEL LINEAR DRIVER CHIP". I HAVE HAD SEVEAL OTHER CHANGERS WITH THE SAME BAD CHIP. I GUESS THEY ONLY LAST 10 YEARS MINIMUM. DOES YOUR CHANGER SKIP WITH ALL THOSE SUBS YOU HAVE? JUST WONDERING HOW MUCH VIBRATION THE CHANGER GETS. IT COULD HAVE JUST BROKEN A SOLDER JOINT. EXCUSE MY CAPS. I CAN SEE THE SCREEN BETTER. I AM NOT YELLING.
OK I sent you a PM. And yes the CD Player skips but only when I play CDR's and I hit a pot hole. Store bought CD's play fine so I think that is a different problem. It even got a little better after I cleaned the lens.
cdx-m8036zt problem
