Speakers Installed...PROPERLY (Official 2GS Install Speaker thread)
Old 07-04-07, 06:03 PM
  #61
TwentyTen
TwentyTen's Avatar
Originally Posted by GSlider
Nice write-up bud! I was wondering what measures I was going to have to go to when I do the install in mine. Now I know.
Thanks! If I were to do this all over again, the only thing I would do different is use a bandsaw if I had one and, depending on the speakers, I might bypass the baffles completely. I used a Dremeel when redoing the back doors and the whole process was faster, the edges were smoother.
Old 11-24-08, 03:19 PM
  #62
waxman
waxman's Avatar
Default Need help!!!!!!!!!!!!!!!11111
NEED HELP installing the oem subwoofer, dont no how to remove it. should i remove or keep it, because i have other one in the trunk. thank you!
Old 11-24-08, 03:46 PM
  #63
TwentyTen
TwentyTen's Avatar
Remove it. This way the sound from the sub in the trunk can pass thru to the cabin.
Old 11-24-08, 04:45 PM
  #64
engin_ear
Everything in Moderation
engin_ear's Avatar
Yes, remove it. You can do so by removing the rear seats, the rear side panels, and then the rear deck cover, exposing the 4 mounting bolts.
Old 01-26-10, 10:38 AM
  #65
Toyboy300
Toyboy300's Avatar
Originally Posted by engin_ear
Nice pics.
I used the smaller Dynaudio mids in that location, they're about 5 1/4", on 1/2 MDF, and then I used some dense foam around the circumference of the speaker (between the speaker and the door panel) to eliminate any vibrations and prevent sound pressure from going sideways. Pics are in the gallery if interested.
One thing to check is whether your speaker is firing directly thru the hole in the door panel. (I can't remember the position that's required offhand....) If not, you may find that the door panel resonates excessively when you turn it up. Just something to watch out for.
I'm planning on replacing my door speakers soon with 6.5" CDT separates. Thanks for the information. What size are your mids and depth?
Old 07-20-10, 12:32 PM
  #66
wutiteez
wutiteez's Avatar
bringing this thread back up from the grave but quick question:
these adapters came with my infinity kappas that i bought. dumb question but will these work instead of having to modify a new adapter?
anyone from norcal/bay area make these mdf adapters? and are willing to install my front and rear speakers with an amp for some cash? thanks in advanced!
Old 07-21-10, 09:53 AM
  #67
toy4life86
toy4life86's Avatar
hey bro whats up those speaker brackets arent going to work but I wanted to see where your located in the bay area maybe we can get together and do it at my house
I can probably make them out of mdf also since i got the plastic ones i can just copy those i sent you a pm too Im guessing your in fremont
Old 07-25-10, 01:31 PM
  #68
3JS
3JS's Avatar
I love the step by step instructons with pics...great work man.
Old 07-26-10, 05:39 PM
  #69
95lexsc300
95lexsc300's Avatar
wow its a mission to replaced the stock speaker thats why i been holding on installing my focal 165kp
Old 10-06-11, 09:19 AM
  #70
richie3888
richie3888's Avatar
Tagged for upcoming project
Old 04-08-12, 04:02 AM
  #71
indytrucks
indytrucks's Avatar
I know this is an old thread but no point in making a new one for a question that can be answered in here. Anyone know the mounting depth of the front/rear speakers without the factory "enclosures"? I'll be making baffles most likely out of High Density Polyethylene (HDP, think cutting board) material in 1/4". Possibly 1/2" depending on mounting depths available.
Old 09-14-14, 05:01 PM
  #72
702GS
702GS's Avatar
Will be doing this as well, great info here guys!
Old 10-22-20, 12:31 AM
  #73
Coffeyface
Coffeyface's Avatar
Originally Posted by TwentyTen
Thanks Engine,
You said it perfect - every voice turn into a horn. I kept thinking, what the heck is wrong here? I took photos of what it looks like installed and will post them later on tonight.
How did you install yours? What size speakers?
***UPDATE***
The fit:
So your running a component set with a crossover. I might have missed it but does your 2gs have the mark levinson system in it?? An what's the impedance of those speakers?? I just picked up an 02 gs430 with Navi and the ML system and looking to install a set of infinity reference components up from and a set of infinity reference coaxial speakers, but I keep getting conflicting information about the Impedances from the factory ML amp and aftermarket speakers. Any insight would be greatly appreciated as I don't want to try the amp or spend the time to have it end up sounding like 💩
orateam
HS 250h Model (2010-2012)
25
02-05-24 05:07 AM
thejace
19
02-23-11 04:01 PM
ByoungWoo
05-02-08 10:18 AM
Baybarea
08-15-07 08:22 PM
olddog
04-08-07 09:04 PM
Quick Reply: Speakers Installed...PROPERLY (Official 2GS Install Speaker thread)
