Speaker Install - "How-To" with TONS of pics!! SC3/400
Old 06-26-06, 03:11 PM
  #76
VinnyQH
VinnyQH's Avatar
hey thanks for your help, i did get my diamond 7" speakers in there. they were a pain.
Old 06-26-06, 06:14 PM
  #77
silkiechic
silkiechic's Avatar
Originally Posted by RSTSpeed
Yea, I'm 99% sure I did everything right... so I'm stumped as to what is different.
hmm. Well good luck, dunno what else to say.
Old 06-27-06, 01:47 AM
  #78
Royicus
Royicus's Avatar
Which bolt, the one at the top of the pillar? I didn't have a problem with it, interesting.
Also, one question for everyone:
After I put everything back together, the back portion of the seat seems to sit higher. If you look at the car from the back, you can see the yellow foam of the seat between the deck panel and the seatback. Anyone else have this problem and/or know how to solve it?
You probably didn't have a problem with it because you put it in straight :P
As for putting things back together, it is really easy to get things a bit off and not have it in quite snugly. If you are getting something that doesn't fit quite right, I'd recommend you remove it and look at the clips/protrusions on the back and visually match them up to the frame.
When silkiechic and I were doing it, she installed it and I looked from the back to make sure the pins/clips/protrusions were all going where they needed to go. Without being too careful, it can be a cm or so off. It will clip back in, but it won't be quite right. Give that a shot and see if that fixes your problem.
Old 09-30-06, 08:47 AM
  #79
Durrr
Durrr's Avatar
An update : on my 92 SC400, the front door baffle mounting brackets are on the top part of the baffle, not the bottom, so you have to make the MDF large enough to cover the factory mounting brackets and cut them out so to say.
I will take pictures after I get some MDF
Old 10-22-06, 07:12 AM
  #80
vince1128
vince1128's Avatar
very nice but i would be scared as hell to try to pull that off lol
Old 10-23-06, 04:05 AM
  #81
southernjo
southernjo's Avatar
Wink amp or amps?
I am blown away at all the time you took taking all these pics, its wonderful..I have not looked all the way thru, but am wondering if you have any advice about the amp...seems my system is only half working, half the apeakers that is...are there two amps? where are they located, and does it have to be a nakamichi amp in order to work?? this is driving me nuts!! thanks for any input you may have and cheers bro,
Southernjockey
Old 10-23-06, 11:42 AM
  #82
RSTSpeed
RSTSpeed's Avatar
Um... well, the pioneer system has two amps - one for the sub and one for the speakers. The speaker amp is located UNDER your CD changer in the trunk - I think you have to take out that carpet panel and the changer as well as it's mount to get to it, but I can't remember. The sub amp is located next to the sub in the rear deck... see above how to get the rear deck out.
The Nak system only uses one amp and it's located under the CD changer as well.
Thanks for the props Jockey... where are you in GA? I'm from metro ATL.
Old 11-08-06, 07:00 AM
  #83
fooldall
fooldall's Avatar
Awesome!!!!!!!!!!!!!!!!!
Old 12-15-06, 12:08 PM
  #84
LEXuriouss
Banned
LEXuriouss's Avatar
how do i know if the sub( i have sittign in my garage) i have is free air or not.... and is 4ch. amp the best for the full set up?
Old 12-16-06, 09:33 AM
  #85
RSTSpeed
RSTSpeed's Avatar
If I'm not mistaken, they're all free-air.
What do you mean about the 4 chan. amp?
Oh, and my AIM screen name is "Lexurious Coupe" - thought you might get a kick out of that. :-)
Old 12-18-06, 09:54 AM
  #86
LEXuriouss
Banned
LEXuriouss's Avatar
muahaha nice nice
and not all subs are air free.
subs-> (most ) are made to be installed in the enclosures.
about the amp: do i need a good 4 channel amp for the full front and rear speaker set up including the sub?
lastly do i have to redrill the hole in the rear for 10 inch sub if im going to get rid of the stock? and will the stock cover fit on top of the 10 inch sub?
Old 12-18-06, 10:14 AM
  #87
silkiechic
silkiechic's Avatar
Originally Posted by LEXuriouss
muahaha nice nice
I think he was referring to the sc's in the thread. All factory sc's have free air subs becasue they are just a few inches above the gas thank. Good luck finding a quality free air sub.
Edit: But yes, most subs ae ment to be put into an enclosure so the one in the garage is probally ment to be in one.
Old 12-18-06, 02:20 PM
  #88
LEXuriouss
Banned
LEXuriouss's Avatar
there is one on ebay..really niiiiiiice but 250$ lol
boooo!!!....
what did you guys replace your stock sub with?
Old 12-18-06, 03:35 PM
  #89
silkiechic
silkiechic's Avatar
Sorry, can't help with that one. Didn't replace it. Still the little 8 in there.
Old 12-19-06, 07:53 AM
  #90
RSTSpeed
RSTSpeed's Avatar
Yea, I was talking about the SC's sub... I misread your question, my bad!
Amp: I'm 99% sure you're gonna need two amps unless you can find a 5 or 6 channel amp - one channel per speaker (so a total of 4) and another one for the sub.
I replaced my stocker with 2 12"s in the trunk, so now the hole where the stock sub used to be is empty and allows airflow into the cabin. As far as drilling... I don't know, but that's a WHOLE LOT OF WORK. Why not just put it in the trunk or get a bazooka tube or something if space is a big concern?
Quick Reply: Speaker Install - "How-To" with TONS of pics!! SC3/400
