Lexus stereo not compatible with bass blockers...
Hello, this is my first post... I own a 93 ES300.
I tried to hook up a pair of bass blockers on the front door speakers. When I turned on the stereo after I installed them the left side did not play. Turns out that the bass blocker were defective. So when I hooked everything up normally again, only the right front and rear speakers work. The front left speakers dont make a sound at all. I think I may have blown a channel in my factory amp...
Originally posted by NebTL
I'm questioning if the problem is my factory amp or is it the speakers?
try this:
take the door panal apart and take the speaker out and test the bad speaker the old fashion way ..with a 9v battery connect +/- to the +/- of teh speaker if it makes a slight pop sound you know the speaker works or switch speakers from one side to teh other and test it that way or if you have a home audio system connect it like that as well. if the speaker works then it cound be your amp ...
bigmoo5
11-01-06 02:09 PM
