System advice
System advice
I'm dropping my car off tonight to get my system installed. I am planning for 2 10W6 subs in a sealed enclosure powered by a JL 500x1. I'm concerned that two 10's may not be enough 'bump'...should I go with 3 10W6 subs and a JL 1000x1? I should have plenty of mids and highs...two sets of MB Quartz seperates powered by a JL 300x4.
Thanks in advance for your advice.
WOW...you don't think a 500/1 per 10" is kinda overkill? If anything I would probably go with 2 12W6 subs...do you think two 500/1's are better than a 1000/1? Can't I run at lower Ohms if two subs are running off the mono? Or am I not thinking right here?
the jl amps (all are mono) are rated at 500 watts no matter what the ohm load....but i think the lowest is 2 ohms. if u have 2 6 ohm subs....the rated ohm load would be 3 ohms...and should be safe to run off 1 amp. i have 1 jl 12w7....and its being pushed by the 500.1. i dont need it to be any louder...it runs the sub fine. im sure your 2 10w6's will run fine on 1 jl 500.
Balance (n): A harmonious or satisfying arrangement or proportion of parts or elements, as in a design.
The 10W6v2 is a great choice for those seeking audiophile sub-bass performance with strong output capability in very compact enclosures. Exceptional linear excursion capability and highly optimized motor and suspension designs ensure linear performance at high power levels. Patented cooling technologies enhance reliability and linearity. Well suited for compact sealed or ported enclosure designs.
Nominal Diameter: 10 inches (250 mm)
Continuous Power Handling: 400 Watts
Voice Coil: 2.75" diameter, 4-layer, Kapton former
Available Configurations: Dual 4 ohm only
Xmax (one-way, linear): 0.60" (15.2 mm)
Sealed Enclosure Range: 0.50-1.00 cu.ft. (14.0-28.0 liters)
Ported Enclosure Range: 0.75-1.25 cu.ft. (21.2-35.5 liters)
VRC™ Technology: YES
W-Cone™ Technology: YES
Elevated Frame Technology: YES
Floating Cone Attach Technology: YES
NeckVent™ Technology: YES
Copyright © 2003 JL Audio. All rights reserved.
Originally posted by johnee78
I am giving advice from experiance and as someone who used to sell these products...I have delt with JLaudio directly and the w6 is rated 400watts rms, where the w3 is rated 250 watts rms..By running a 500/1 to 2 speakers that are rated at 400 watts each your actually underpowering them by giving them only 250 watts..Now if you run 500 watts to to each your actually running them at peek power and giving yourself some head room..The JL slash series amps use a system called "R.I.P.S."-Regulated, intelligent,power,Supply. Basically this means that the amp will play at the rated power between 9.5 volts-15 volts and 1.5ohms-6ohms..As for whether you should use one or two, I would recommend 2 and that is directly from JL.!! The reason for using 2 amps is so that each sub is getting their own power supply and not feeding off the same source..Hope this helps.Heres a spec sheet from JL audio-
koreanpers -I noticed that you are using a 500/1 for a 12w7, which is underpowering the woofer..You are probably satisfied with the sound because it is firing directly into the cabin of the car..Opposed to having to travel from the back of the trunk and then into the cabin..I am suggesting the max power for the woofers 1- because they can handle it and 2- because silverlexo has made it clear that he wants loud bass...In order to get very loud bass you need power and a slot port box that is ported into the cabin of the car through the factory woofer opening..The combination of the 2 is really loud!!! ..
Hmmm...I've always been a fan of 12's & I know they can fit in a custom enclosure under the rear deck so I can still get to my spare tire. Now the choice may be to run two 500/1's vs. one 1000/1. Is there no benefit to running off of a single amp?
Another advantage of running 2 amps is that your not limited to where you can mount your amps..Where the 1000/1 is 1 long amp you have the advantage of 2 smaller amps...Just some more pros..What alot of people don't know is that JLaudio released the 1000/1 strictly for the 12w7 and the 13w7 because there isn't any other amp out there that can push 1000 watts at 3ohms..So these amps were built with intention to used as a single speaker amp..
I've had bad experiences with ported boxes...it seems that a sealed encloseure is the 'safest' way to go for all aruond good sound. But what would your recommendation be on the slot port? I assume they would have to be on the edge of each sub enclosure so they would meet up in the middle and fire through the stock sub opening...what about the area of the slot...how big? (2 12w6's)
johnee78 - There are actually plenty of amplifiers out in the market that can push 1000+ watts @ 3-ohms. It's just that JL Audio marketed their amplifiers to be the "perfect amplifier" for the W7's because of the W7's limited voice coil configuration (nothing wrong with it since it collects the money). Their monoblock amplfiers can power other brands of subwoofers just as easily (given the correct ohm-configuration, etc.) as W7's.
OK...I've decided that I am going with 3 10W6 subs with a 1000/1 amp...I'd like to go with 3 500/1's but my budget doesn't quite fit it in. My car is at the shop and they are laying the wiring down right now.
Does anyone see a problem with mounting the rear seperates as a coaxial style...will they fit in the stock location?
Hi, i did the trunk mount in my car. i custom mounted the 12 in the rear deck, firing into the cabin. we had to cut the rear deck out, to accomodate the sub. i have 1 12w7 as discussed earlier. I also have the jl spec slot ported box. the bass is unbelievable. and no trunk rattle....heres the link to the install here...
My sub install
My sub install
I've had people at shows tell me that my 10's sound like 12's when I bump hard. I guess it all matters how the box is built, how much power your pushing, and how the system is tuned... Good luck with your choice!
