Carputer - SC guys what do you think
#151
I cut out a piece of thin cardboard and then hotglued it onto the back of the trim. I then used bondo hair to fill in the bigger gap. It has little pieces of fiberglass strands in there so it's super hard and it won't crack.
I also cut off the complete backing of the cupholder so I didn't have to use too much filler later on.
Tony
Tony
#153
Originally posted by DaizenLex
To deal with the FM issues, you can get XM... Goes directly with the carputer,
#155
I recorded a quick 45 second clip of the carputer in action playing mp3's and music videos.
I still have to find a good location for my GPS unit so I haven't hooked that up yet...I'm still in the process of loading up my harddrive with stuff to keep me busy when I'm bored in traffic...
The video clip was made with Dr. Divx and you'll need divx codec to watch it...I'm loving this Divx encoding...original size about 7mbs...divx encoding takes it to 1mb without too much sacrificing of video/audio...
Right Click Save As
some updates: I fit the mobo, a 2.5" HD and a 3.5" HD all behind the radio location. You will definitely need to modify your center radio trim area for better cooling. I'll be adding a HD fan and maybe cutting holes on the sides to mount 2 more fans. The powersupply is in the glove where i'll be fabricating a face plate to allow a dvd rom or more external harddrives.
Right Click Save As
#157
couple questions,
so the motherboard you bought is made for carputer applications and uses the cars powersupply or how does that work? also what speed processor are u running or am i missing something here?
and how are u powering the external HD?
#158
The motherboard is simply a mini-itx board. I chose this board because of it's size, 17cm x 17cm. Although its small, it packs a lot of power compared to some full size computers. The power supply is a special powersupply made to work in vehicle applications. www.opussolutions.com
As for the external HD, i'll be using an external firewire case and run the power for that off the car or maybe use an inverter...I don't know, everytime I jump in the car, I think of new ideas to redo my system...I've already rearranged the system 4 times and probably going to do it again tomorrow.
Glad you enjoy!
Glad you enjoy!
#163
Yeah, no radio for now, but the good thing is that it's always upgradable. Over 20,000 mp3's is plenty don't you think? To play music though, stick to mp3s because .wavs take up about 10x more space compared to it's mp3 counterpart.
I just added 10 movies last night , 5,000 NES games, 15000 Gameboy Advance games, and about 4,000 more Mame games. Now all I have to do is run a 4 port USB hub to the rear tunnel mat area and I can have some 4 player competition!
The paint used was low gloss black. It looks more like flat black to me, but i'm going to redo the whole trim/mold next week.
johnee78: depending on which monitor you want, most people use either Lilliput (~$275) or the Xenarc (~$460), then you can build whatever type of computer you want. You can throw in your old computer case if you wanted to in the trunk and wire it to the front of the car. I chose this small mobo because I wanted it to fit behind the monitor which it does.
#164
alright, so lets say i wanted to use an old computer case -- What kind of power supply would I need to switch it over to the car power (plz tell me what u bought is the cheapest they come, 200$ is kind of expensive for a power cord -- also do you think there would be any heat problems back there, and what about my 2 12"s in back? I already have problems with the amp overheating if I drive for too long.
and what kind of processor u running in there?
#165
Originally posted by the_ez_rhino
1) What kind of power supply would I need to switch it over to the car power (plz tell me what u bought is the cheapest they come, 200$ is kind of expensive for a power cord
2) and what kind of processor u running in there?
2) The M10000 uses a 1ghz VIA processor. Those processors are considerably slower than any Intel/AMD offering with the same speed. But there are no motherboards that are that small that use either the AMD or the Intel processors. Also the M10000 is cheap considering you get a whole CPU/motherboard combo
