Carputer - SC guys what do you think
#168
Originally posted by ACleanSC4
You set the carputer to go into hibernate mode and that will not drain your battery if it's your daily driver. Boot up from hibernation is about 5-10secs.
You want one huh jess?
#173
Abboushi: the via epia mobo i have is capable of 6 channel output. So using their software, I changed the jacks in the back out to 3 outputs. Used a converter to RCA's and plugged them into an amp. I'm still saving up to redo my whole system so I didn't do it cleanly yet.
Sound is pretty good though...
The you can get any computer to output to an amp but you might have to buy a soundcard. The via epia boards(the newer ones) are capable of 6 channel output. The shuttle boards might not be able to do that so you'll need to buy a sound card...a lot of people use the sound blaster audigy 2x or x2..something like that...
#174
While the board is capable of 6 channel output I do not think it is good. Its like comparing a Kia radio to a Nakamichi one - its obvious which one is better. I have used the onboard audio on my motherboard when my first Audigy died - the sound was awful, and this being on a very recent board. The difference was night and day when I got an Audigy 2. The Audigy 2 is THX certified, and they have one with support for 6.1. The Audigy 2 also decodes DVD Audo, and a lot of other features. When I build my carputer I will use the only PCI slot for the sound card, the rest can be on the USB. The problem I've heard with the Audigy 2 EX (External) is that it ties up the USB bus with all the data.
#175
#176
0l33l : when you get your SC...definitely do a carputer and post it up. If you're just going to stick a computer case in the trunk, then yeah adding another sound card is the way to go. But I have my computer behind the monitor and there's no room for a sound card.
So conclusions? If you're going to put a computer case in your trunk, definitely get a good sound card. If you don't really care, you can fit the mobo/hd behind the monitor.
Well version 2 of my carputer is already getting underway so more updates will come...Thanks gazi for the extra glovebox, I'll try to make something nice out of it.
Tony
Tony
#178
Tony
Tony
#179
Originally posted by aliga
im back in ny.
tony im glad you can put that glovebox to use, it was collecting dust on my side.
keep up the good work.
im back in ny.
#180
Originally posted by 0l33l
I'm gonna stick it in instead of the radio. You don't have place for a sound card because you probably didn't use a right angle riser card.
