LS400 questions?
Does anybody know if there are any online tutorials on how to install a DIN size headunit in a 1st gen. LS400?
And is there a kit that makes the wiring a plug n play affair?
I have a couple pairs of Infinity reference 5.25i component speakers, the first pair will go into the stock location in the front doors, the second pair I would like to put in the rear, but the rear doesnt have any holes for the tweeters.
Where is a good place for the tweeters for the rear passengers?
I would like to do the installs myself to save some bucks and to learn aswell. So any help will be greatly appreciated.
VIP|EXEstyle セルシオ
Hope this helps (off of Earl!'s LS website
For installing aftermarket head unit (tells you which wiring harness to use as well):
http://www.lexls.com/head_unit.html
For installing 5.25" speaker:
http://www.lexls.com/front_speaker.html
More:
http://www.lexls.com/tutorials.html
I'm a n00b when it comes to AV... maybe some of the AV gurus can chime in and help you out on the last question.
More:
Leaving the rear tweeters out is not necessarily a bad idea- most high-end car stereo setups only use 2 tweets in front to get the best possible imaging.
cnewman402
33
11-10-22 08:20 AM
bornking
36
07-12-14 08:42 PM
