Amplifier Location
Vermont,
It is under the front passenger seat, and it is very easy to remove. Slide the seat all the way forward and remove the heat vent cover by prying up the plastic screw covers explosing the screws. After removing the vent, you will see the connections and the 2 bolts securing the amp. Once they are removed slide the seat all the way back and you can pull the front side out of the slots that holds it in place. Easy.
Migjam
Migjam
kjhouston
21
07-27-22 02:13 PM
