Anyone running 6.5" in the front?
I know you can fit 5 1/4 but wondering if we can use 6.5 simply because the mid bass is much better. It defeats the purpose of an SQ system w/o the mid bass.
Everything in Moderation
It depends on the particular dimensions of the speaker that you're thinking of putting in. You need to make sure that there's clearance for the window at the bottom of its travel. If the speaker is too deep, it will hit. You can space out the speaker with a spacer ring or whatever, if you can keep it behind the door panel/grille. Make measurements after you pick a speaker to make sure it will clear. At a minimum, you may need to mount the speaker as far forward, toward the front of the car, as possible.
The One
I have boston pro 6.5 midbass drivers in my front doors..I made a new enclosure out of mdf and fiberglass and covered it in raamat to avoid any rattling..Kicker makes very shallow 6.5 speakers and I am almost positive that the MB QUART speakers will fit if you make new enclosures..You may also want to check into CDT and image dynamics..
I had CDT's in my previous vehicle and didn't like it. The tweeter would get cut off @ higher volume because the xover would go into protection mode. Tried 2 sets both did the same. But @ moderate volume SQ is by far one of the best I've heard. I like the MB Quart sharp sounding tweeter a little more expecially when I plan on doing a coax mount where the tweets would be far away from the ear vs @ the door panel where it's @ ear level then it can be pretty loud.
dannieboiz-
I agree that the mb quart tweeters are a bit harsh when mounted at eye level but mounted co-axially would really tone down the tweets...The CDT's are great speakers, but I'm curious about which model did you have and how much power did you have running through them..I never heard of them going into protection..
I was using the CL series, first powered with a fosgate power 800a4 then I had them on an orion 8004. after that I did a vifa PL 7" and the upgraded version of the CDT Tweet with my kicker res xover and I absolutely love it. Mid bass on the PL's are great and the CDT tweeters were not bad either but they were too far away from the ears. They seem to have a hard time keeping up with a pair of 12's Eclipse Alum.
The vifas provide excellent midbass!! I just couldn't fit it into my door without modifying the door panel and I didn't want huge kicks in the way..My 5.25 kicks take enough space as it is..If you were running a 800.4 you were probably running too much power to your speakers becaue they are only rated at 170 watts rms..the cdt tweets probably don't seem to keep up because they are silk domed instead metal..the silk dome tweeter will almost always give you a more natural sound opposed to the metal dome that will play louder in some cases but tend to be harsher in sound, MB quart is a prime example..Speaker placement is very important as you probably already know and maybe moving your tweeters higher will increase your sound and raise your sounstage..Are you using anything for rear fill??
I had kicker resolution 6.5 components but since I blew one of the tweeter I replaced the fronts with the VIFA and brought the 6.5 to the rear and use it as full range for rear fills. Been working out great.
O.K. I am in the same hole. Am planning to replace the door speakers in my Lexus GS-400 2000. So far , the ones I like more are the Dynaudio either 220 MKII or 240 MKII . The first are 6" , the second ones are 7". I have 2 questions : 1) Are the modifications that I will have to do on the doors almost the same for the 6" or the 7" , or , going with the 6" will be easier on installation that with the 7" . If it `s the same , I will go with the 7" . 2) What about the rear doors ? Do I have to buy another component set of Dynaudios ? Because I will be using only the midranges, not the twetters.... Maybe Dynaudio sells the midranges (MV150 or MV160) separately. Anybody knows this ? Please, am stock. Thanks ps: I already replaced the stock sub with a 10" Infinity in box, and a mono Zapco amp. Josey
Also, anybody has the new 240 Gt Dynaudios installed ? I believe it has the same perfomance of the 240 MKII, but 6.5" instead of 7". I will like to know if they are as good as the MKIIs ,so then I`ll get them. Thanks so much.... Josey
