Has anyone moved the battery to the trunk?
i relocated the battery in my 91 celica alltrac before i sold it ... i just bought the universal kit from summitracing.com but i think it could be done much cheaper if you can figure out a way to make sure the battery is secure. I ran the wire under the carpet through the passenger compartment but on the lexus you might not be able to find an easy in through (or around) the firewall As far as wire gauge ... i donno it was big tho lol
lexusfiend
lexusfiend
Originally posted by ACleanSC4
i had my buddy do it for me...ran 0 gauge wires under the carpet to the trunk in a battery case with cover...
fits pretty nice in the old 12disc changer spot...
Or for all you monty python fans...
King Arthur: "good idea Oh Lord"
God: "Course it's a good idea!!!"
FWIW,
There is a risk in this type of installation. You are running an unfused battery lead through the pasenger compartment. If this wire is damaged and the conductor comes in contact with the frame you would get some impressive fireworks.
-jim-
-jim-
Originally posted by jstjohnz
FWIW,
-jim-
FWIW,
-jim-
anyone with a pic of stock 12CD changer spot? my car didn't come with CD changer...
Originally posted by VSsc400
good point... I will definitely put a fuse on it...
-jim-
Fusing
You can get some large Fuses and holders from car audio compaines like stinger that use 1 or 2 ANL syle fuses (up to 300 Amp each) the crazy high amperage shouldnt matter beause all you are doing is protecting against a short and in the case of a short these would blow with out a problem. Hope this helps, Metal
http://www.stingerelectronics.com/we...stribution.asp
Part# SHD2ANL
From what I found from Toyota their starter on a 4cyl draws 130-150 Amps and on a 6cyl draws 175 Amps (I cant see the 8cyl drawing that much more power) so you should be able to properly fuse with the fuse holder mentioned above.
Part# SHD2ANL
LocknRoll
13
03-19-06 11:21 PM
