After Market Amp
After Market Amp
Im trying to install an after market amp where would i run the Red wire from the battery to inside the car is there a hole where i can put it in. I already have an after market Head unit all i need now is the amp to get Power let me know thank you.
Hey man,
There should already be a hole drilled into your firewall - if not get out your drill! Just make sure you know exactly where u r drilling so u don't hit anything. Then u r gonna have to run it underneath your carpet all the way to the trunk if u r planning on putting it there.
Good luck,
Jonny
Good luck,
Jonny
TwentyTen
12-10-03 08:58 AM
