LS400 Stereo Dash Kit
Anyone here use the "Best Kits LX3 " kit in their ls400. I notice it comes wit 2 faceplates. I wanted to know if one faceplate is for a single din and the second for a 1 1/2 din, say for a stereo and a 1/2 din eq, or are they both the same? Also anyone use the "metra kits" I have a 90' and i can only find kits for 95 and up for the ls400. Anyone have any luck in getting even just the face plate to work in a 90' or 91' ? I am looking to put in a stereo an a slimline eq. without having to custom make a faceplate.
Thanks in advance
Thanks in advance
They are both only for the Din type stereo, it does not come with the half-din for the slim type EQ. Unit has to be modified to fit both the deck and the EQ. As you stated, the only ones I have seen also that come with the One and a half-din are for the 95 and up LS400 and I believe these are made of ABS plastic, where the LX3 are metal.
Thanks, for the info. Hopefully I'll be able to modify it (LX3) fairly easy with a dremel. I'm going to go to stereo shop and see if the ones (metra) for the 95' and up with the pocket will fit in my car with some modifications. If not I'm just going to go with the LX3. I guess if I mess up one faceplate I'll still have the second one.
Tote
Tote
elite7
11-12-11 04:59 PM
mrwoolery
01-29-11 01:38 AM
