Radio fuse
Where can i find the radio fuse mine doesnt even turn on, and i dont have the box under the kick panel which lets me know which fuse is for the radio , i need the location of the fuse itself. thanks
when you are looking at the box it's the 3rd or the 4th one from the bottom on the back row.
I changed mine a few weeks ago and I'm 90% sure that's the one.
100% sure it's in the back row when you are looking at it.
if not, at autozone you can buy the fuse kit (comes with assorted fuses and a very compact fuse checker for about $6) and you can go through them.
good luck.
good luck.
I had the Nak and when I cranked the volume up, I blew a couple fuses.....funny
I just looked in my owners manual and saw which one I had to replace. But Dennis is right - it's like the 3rd or 4th one back.....
And buy "a few" - it's happened to me often....
it's not recommended to put a larger one. In case of emergency i guess you can go +5amps but should be replaced with the correct amp fuse. Let's say if you put a 30amp fuse in where it calls for 15 when you have a surge or a short you will be sure to blow the equipment rather than just the fuse.
gqr1c3boi
03-13-08 08:39 PM
