Location of Vehicle Speed sensor on 00 GS400??
Hello, im just wondering .. How many different wires are there that can act as the vehicle speed sensor to connect a navigation unit to?
I got 4 possibilities: 3 are from here and 1 is from the12volt.com
Here are the 3 from this forum:
"red/blue wire - 17 pin plug, pin #11 located inside ECU box which is under hood on the drivers side"
THEN
"here's the definitive location of the '00 GS400 vehicle speed sensor wire. It is a Violet wire with a white stripe located in a blue color 6 pin plug underneath the driver's dash to the left of the steering colomn."
AND
"the speed sense wire is red/blue, it's in the ECU under the hood on the drivers side in a 17 pin plug,pin 11, your brake wire is green/white in a 20 pin plug in the drivers kick panel."
This is the one from the12volt.com
"Blue/Yellow - Pin 5 Connector E4 in Black Box Driver's Side of ENG "
Are they ALL right?
Please help.. thanks.
THEN
AND
Are they ALL right?
bklynboi
03-25-10 08:53 PM
lexoman
10-31-04 06:59 PM
