custom enclosure ?????
i made a couple of boxes in the past, i know the 1728 equation but now i got to make a custom fiberglass enclosure but i don't know how do i get the correct volume inside. (it's an irregular shape)
is there another way to correctly mesure this.
thankyou for any help
styrofoam peanuts would be easiest to get a rough estimate....just fill up the enclosure and then measure how many peanuts you used... There is a conversion but I cant remember right now.. YOU could make a cardboard box that is 1 cubic foot and just use that to measure how much styrofoam you have..
Everything in Moderation
Originally posted by sc3boost
so i actually have to make the enclosure first and then measure it with some liquid or sand then find a way to convert it to cubic inches.
If you want to be really accurate, use water! 7.5 gallons = 1 cu ft.
Just be sure to double up on the plastic lining- the 6 gallons you see here would not be fun to siphon out!
water seems to be the best way since my system will be in my wheel well.
my buddy had a custom shop and he had this program that he use to use to make banpass and ported boxes, heve you guys ever heard about this.
and also 7.5 gallons = 1cubic foot......................................right
xcorpion47
10-10-23 07:22 AM
BIGMerle
09-12-11 06:37 PM
