help with alarm on my gs
hey guys i need help with programming the key scense....i got it where it try to start but doesn't i have a prestige 2 way fm alarm i need help putting the remote start feature in it .... i have the DEI 555f by-pass but i think i'm having trouble programming it with the key ...can any help me with this and how to wired up the door locks.....thank you
If you followed the programing instructions than the ring may have to be moved until it recognizes the resistance with the key out. It is common to have to move them a little till you find the right spot. Try to start it with the key in to make sure you dont have a different problem first. May be a 2nd ignition wire not being powered up which will do the same thing or even a bad tack signal.
SC_4_Me
01-22-24 12:50 AM
Lexiss_sc430
11-12-06 02:17 AM
