1st Gen GS300 have amp(s)?
What kind of system does the stock first gen GS have? Does it have an amp powering the speakers/sub? If so what ohm is the sub powered at?
THERE ARE 2 GS SYSTEMS. THE NAK IS 4 OHM SUB AND THE PIONEER IS 2 OHM SUB. BOTH SYSTEMS HAVE A 5 CHANNEL AMP IN THE RIGHT REAR QUARTERPANEL. THE SPEAKERS ARE 20 TO 40 WATT ON THE DOORS AND 80 WATT SUBS BOTH FREE AIR. THE PIONEER FRONT DOOR SPEAKERSA ALSO 2 OHM REARS 4 OHM. THE NAK SPEAKERS ARE 4 OHM ALL AROUND 4 INCH. THE NAK SUB IS 12 INCH THE P[IONEER SUB MEASURES 10 INCH BUT IS IN A 12 INCH HOOSING SO IT WILL FIT IN THE SAME BOLT PATTERN AS THE NAK SUB. THE WIRING HARNESSES ARE EXACTLY THE SAME SO NAKAMICHI SYSTEM IS PLUG IN AND PLAY CONVERSION FOR THE PIONEER.
mhsu408
01-22-06 06:35 AM
sickntired
03-01-05 02:09 PM
Kajukenbo
08-06-02 09:48 AM
