new battery needed
Old 10-06-04, 11:47 PM
salimshah
salimshah's Avatar
Received 1,059 Likes on 955 Posts
Default Re: Which one do you get?
Originally posted by chuckb
when
i go to www.optimabatteries.com they don't list any application for GS400 or GS430?
The Optimas are not a direct-replacement.
To make them fit, remember to get the short standoff (new optimas come with this elevator trays that snap on to the bottom). With that in place battery height will still be 3/16" or so short. To get a tight fit you may have to purchase shorter hold-downs.
The next problem will be with the terminal leads. On the Optima the posts are further away from the corner of the battery. One can force fit.
Salim
Old 10-07-04, 12:23 AM
GSspeed
GSspeed's Avatar
okay so RED is for every day driving, what about power is it enough,
and YELLOW is for additional equiptment in the car,
so wouldnt yellow be a better buy, if it is for every day driving, and stereos too.
Old 10-07-04, 01:15 AM
Kohinoor
Kohinoor's Avatar
red has higher cranking amps and is used for everyday apps
yellows are usually added as secondary batteries in the trunk for audio systems
blues are for marine use - boats..
Old 10-07-04, 01:17 AM
GSspeed
GSspeed's Avatar
ahh, i see, so RED is better,
so then RED it is, is there any specific RED or all the same
Old 10-07-04, 03:13 AM
lexusondubs
dubsonlexus
lexusondubs's Avatar
red are all the same...... and HOEBAG is right red is for everyday they have high CA mines is scratched off its in the 900 somethings and the CCA is 800
Old 10-07-04, 03:16 PM
dlomshek
dlomshek's Avatar
Thumbs up
I use an Optima Red-Top and it performs flawlessly. If I had more audio stuff
I would probably use a Yellow-Top Optima.
Old 10-07-04, 06:56 PM
GSspeed
GSspeed's Avatar
thanks, ill go look at them then, costco had a deal for the red one it was 99.00 the model 15, but im not sure if that is the one,
sorry for the thread in the wrong section.
sulaiman
12-05-12 06:25 PM
3sgte_slow
05-14-12 08:34 PM
KKRlexus
02-05-09 10:18 AM
josephdoc
05-30-07 11:11 AM
SSmith
SC- 1st Gen (1992-2000)
01-16-02 06:54 PM
Quick Reply: new battery needed
