SC300 SC400 Power Door Locks
Old 09-17-03, 11:40 PM
Taka
Taka's Avatar
hi Fargo, can you explain whats not working?
i think if the dome fuse is gone, it affects power lock & keyless entry, steering wheel adjustment, memory seating etc..
I left the manual in the car today so I can't check the "dome" fuse location but if your keyless entry system is not working, it could be something else causes..ex)keyless entry ECU, circuits, battery, ECU ROM etc..
Old 09-19-03, 06:43 PM
Fargo
Fargo's Avatar
Taka.... Simply, the button on my key will not lock, or unlock the doors. The problem just occurred this past week. As I said, I replaced the battery in the key, thinking that was the simple solution to the problem, but still no lock / unlock function. I haven't checked anything else so far. Any suggestions before I start would be appreciated.
Old 04-11-04, 08:51 AM
dean s
dean s's Avatar
Default just a thought
Fargo I know this is crazy but did you accidently hit the auto switch under your dash?mine is on the left of the stearing wheel and that has happened to me.
Old 04-11-04, 02:53 PM
Philly#1 Lex
Philly#1 Lex's Avatar
I have the same problem asd fargo with the keyless entry on my key it doesnt work. ANyone with suggestion would be helpful!
Philly
dandtlee
SC- 1st Gen (1992-2000)
01-08-12 10:03 PM
quiktc3
07-10-11 12:04 AM
jay33
06-08-11 06:06 AM
mdfdsc300
03-25-08 11:40 PM
yov6cam
03-16-03 10:15 PM
Quick Reply: SC300 SC400 Power Door Locks
