GS400 with NAK, intermittent sound from front speaker
I have a problem with my speaker and was wondering if my amp or speaker were bad. Can any one help?
I have the stock NAK sound system and once and a while the front drivers side speakers cuts out to a really low sound (if any at all). I can fix it easily by turning the radio on and off real quick. I brought it to the dealer and they couldn't reproduce the problem.
I did a forum search and found others had the same issue but no resolutions, except replace the whole sound system.
I don't believe it's a bad connection since it works 100% after i repower the head unit.
Any ideas how to test the amp?
Could it be a faulty speaker? (I hope that's all it is)
Thanks,
Jim
Thanks,
Jim
Everything in Moderation
Not likely to be a faulty speaker - the problem would more likely be constant in that case. Prob bad amp or headunit output. Intermittent will be tough to trace - and can cost you money if you're paying for someone else's time. Might want to wait and see if the prob gets any worse....
almeshtaq
04-25-19 10:35 AM
EyesOnly
09-14-08 08:56 PM
sliva001
06-13-07 10:54 AM
olddog
21
05-10-07 06:16 PM
