headlight removal
Hey Guys,
I tried to do a search but could not find anything....
I am trying to remove the headlight on my 1992 SC300 to put on my body kit. I got almost all the fasteners off except for the one under the headlight. There is only on screw (on the top) that I can see to take off, but the headlights wont come out...
Any suggestion and pictures would be very helpful....
Thanks in advanced!
VR
PimpluxGS
Thanks in advanced!
VR
PimpluxGS
Hey, you have to get under the wheel wheel and pull that protective layer out quite a bit on both sides. After that is done, you will see where the headlight meets 2 screws, you'll need a socket extention. Be patient with the drivers side headlight as the winshield washer fluid resevoir is there and it really gets in the way.
have fun!
have fun!
Its actually 2 10MM bolts at the back of the headlight near the fender, go ahead and pull that inner
fender back and have at.....
Dont feel bad, I had to look it up when I got to that point too.
