n00b question: can i had 2 pioneer 12'' subs and an aftermarket amp to....
can i had 2 pioneer 12'' subs and an aftermarket amp to my stock premium sound system? i drive a '99 gs300 and my friend is taking his system off of his beamer and handing them over to me.. its really powerful and nice- i like it. and its a cheap alternative also until i have afford to do a custom install. will i have trouble adding these two subs and the amp to my factory sound system? im not looking for ULTRA sq im just looking for added bass. please help!
You can use a Line Level Converter and tap into your OEM sub speaker wires and then feed that to your aftermarket amp. You will need to run a power wire from the battery all the way down to the trunk area. You also need to ground the amp to a good ground locations. You also need a remote turn on so that the amp turns on whenever your car ignition is on. It's not that hard to do. It is also recommended that you remove your OEM sub so that it acts as a port for the bass to enter the cabin.
lex1997
02-03-03 10:06 PM
