SC400 Nakamichi Amp wiring
I did a search but I didn't find an answer.
My amp keeps on turning off randomly. I don't have any clue to why it does. It turns back on when it feels like it (few days, few weeks, whenever). I don't even have it turned up loud.
I'm currently using a LLC tapped in to the wires coming out from Socket 'C' of the nakamichi amp. The remote turn on is using A11 (socket A, #11).
Any reccomendations?
BTW, if you don't understand what I'm referring to, check out this program (it's copyright Microbyte and i can't find it on the website any longer)
http://www.colexusclub.com/nick/scnak.exe
even though I "had" the pioneer system, my amp would also turn on and of randomly. the problem??? If you have a fuse box on your power wire leading to your amp and the fuses anre not tight in contact with metal, the amp will turn off because the circuit is not being made. also, check to see if the fuses on the amp are tight and snug. Make sure all wire conenctions are tight. Loose wires= amp that works when it wants too!
aporozco
10-14-10 11:31 PM
