What do you think of my new system?
Got this system for a steal. Its used for a few months but everything looks/works perfect. Its an 12" Audiobahn AW1200Q subwoofer, in a ported Qlogic 1.25 cu.ft. box, hooked up to a Pioneer GM5000-T amplifier. With the sub bridged it'll be pumping out 380 watts rms. To install it I know Ill need an LLC and I think Im gonna go with 4 gauge wiring, sound good? Im also goin to be removing the stock freeair crapper sub
Ill let you know how it turns out when I install it. Any comments/criticism very welcome.
PS. When installing the system, should I install the LLC before the stock amplifier or after it right before the stock sub (which will be removed). Or should I remove the stock amp (is that amp used for anything besides the stock sub?) and install the LLC there?
PSS. This is in a 92 SC3 with the stock Pioneer system
![](http://akamaipix.crutchfield.com/products/2002/037/h037AW1200Q-o.jpeg)
![](http://www.soundsideperformance.com/site_images/big_photo/354_~GM5000T.jpg)
![](http://akamaipix.crutchfield.com/products/2003/044/h044H1212se-f.jpeg)
Leave the stock amplifier alone. Tap into the wires somewhere close to the middle of teh amp and stock sub. If you ever want to go back and re-install the stock sub(if you sell your car) this will allow you to properly connect the stock wires back together. Did you get a chance to hear the setup you are about to install before you bought it? Audiobahn is decent. The lower level subs lack in areas such as definition but you should be fine. When you install it and if for some reason you don't like the sound, get a box built to its specs. Q-Logic is solid though. 4 gauge wire is plenty big for your application.
Oooooh another question. So the sub is a dual voice coil, but it appears as if it the previous guy only wired one of the coils in the box. So I need to know how to run one bridged channel to the single hookup on the back of the box, and then split the signal to both coils. How would I go about doing this?
PS. Wait I think I found it, would I do option #1? http://www.crutchfieldadvisor.com/S-...pedance=DVC4x2
And about hitting harder than the stock sub, I sure hope so haha
either option will work, it just depends on how your amp runs at the Ohm level and what DVC option your sub is Dual 2 or D4.
One more thing, it will hit harder
I have a 15 in the trunk with about 700 watts and sometimes I still want more bass. It is just hard to get all the sound from the trunk to the cabin.
Well I just installed it this weekend with the help of Pirate400's and SupraCoupe3's guides. It was pretty damn easy, especially for my first installation ever. I really like the results too, the sub hits hard, or hard enough for me atleast. Its also suprisingly clean. I ended up having to install 2 new terminal cups myself and sealing the box with lexan and silicone (instead of leaving it ported), and Im very glad I did. Heres some pics:
(The power wire was just running like that temporarily, I have it properly routed through the rubber things on the side of the rear seat)
Total Cost: ~$125
![](https://www.clublexus.com/gallery/data/500/16363Sub2.jpg)
![](https://www.clublexus.com/gallery/data/500/16363Sub1.jpg)
![](https://www.clublexus.com/gallery/data/500/16363Sub3.jpg)
![](https://www.clublexus.com/gallery/data/500/16363Sub4.jpg)
Total Cost: ~$125
hey whats going on man, nice set up you got there...yo do you think you can email me the pics of your LLC hooked up and the fuse so i can see how you did it and where you put those because i got my power wire and the ground done...its just the fuse and rca converter that i need to finish installing and im kinda clueless
....please email me at supraman3001@yahoo.com with pics and steps for DUMMY'S on how to hook the fuse and rca if u can..thanks in advance
![](https://www.clublexus.com/gallery/data/500/16363sub5.jpg)
![](https://www.clublexus.com/gallery/data/500/16363sub6.jpg)
hey whats going on man. thank you so very much for taking out your time and helping me out...i see how you got the rca wired but do you think you can take some pics of the LLC positive/neg wiring going into the sub and show me how exactly u hooked the wiring to the sub and which sub...also, i cant find your post on how to wire the fuse...perhaps you can send me the link for that or take some pics of the fuse box and the fuse wire and show me where to put it "for dummys" lol...thanks dude, i really appreciate your help!
