ECU Learning On GS's
hey guys, have you been reading the GS forum about the adaptive ECU? i thought with all your brains in here maybe you'd be able to come up with a fix of some kind so that we would be able to disable the adaptive driving for good. just make it always as responsive as possible. I know you can reset it, but a permanent fix would be well worth it.
One way I can think of right away is to change the power connection to the ECU so that every time you turn your car off you also turn off power to the ECU.
But can you turn the ignition back on if the ECU is off-line? I would guess not. Then that wouldn't work...
Clara13
04-08-16 07:59 AM
