After Bodyshop work, Sub doesnt kick as hard
Okay guys need some help here, I picked up my LS (Pioneer system) from the body shop last week, there the rear deck/trunk/rearend was completely stripped to the metal, and put back together. Now my bass does not sound as good as it used too, the sub will start (farting) when i put the bass up (passed 2 o'clock on the ****) , instead of kicking hard as it used to on the same tracks.
What should I check? I looked at the sub visually and I can’t see what’s wrong. Thanks for your help.
most probably it is not seated correctly or installed back in position.
and could very well be blown as well. so you'll have to take off the grill and visually inspect.
what year lex are you referring to ? in the first gen models all you need to do is pop the grill on top of the woofer and you can take the woofer out.
perhaps yours is located differently.
keep us posted.
keep us posted.
It sounds like most of my Bass is coming from the two from mids, not the Rear Sub like it used too.
I don’t see any visible damage to the actual sub, can it be damaged where i cant see?
Let me know so the body shop can fix it since they guarantee their work.
They just dont kick like they used too
unit74
04-15-07 11:54 PM
TwentyTen
31
11-12-03 10:45 PM
LexusRules
01-28-02 06:14 AM
