Dyn MW170 or 60s
Moderator - Electronics Forum
Even with door mods, the MW170's won't fit due to the speaker mounting depth. The 160's will work if there is a spacer ring.
170's will work if you're using a kick pod configuration.
Percy
Percy
I'm using 1 inch spacer rings with 1/2 inch mdf/birch. Others have had different combinations (1/2 inch spacer?) with good results. Don't go with anything more than 1/2 inch on the baseboard, otherwise the door may not go back together properly.
Percy
Percy
Originally Posted by fast400
Has anyone tried to put the Dynaudio MW170s in the front doors of a GS400 without door panel mods?
I know the 160s will fit.
Using MD-100's with Diamond Audio s600 mid bass driver. Saving the MD-130's & MW170's for my newest "toy " in the collection.
Percy: Check your PM.
Gents,
Rebirthing an old question....
Has anyone tried to 170s in the front doors of a 2000 GS4 by modifying the door skin? I'm just wondering how much a panel to replace it if I sell the car. Anyone know where I can get a pair cheap?
Also Percy mentioned kick panels for the 170s? Where would you mount such a thing.
System to Date:
Zapco 1000.4 Running MW160 and 130 tweeters Biamped
Zapco 500.1 running Focal 27v2 (10") sub mounted in a custom back deck enclosure
System to Date:
FuMoFFuTT
SC- 1st Gen (1992-2000)
15
06-25-10 10:54 PM
OutlawTita
08-10-05 03:06 PM
Purplexed
07-24-01 02:06 AM
