93' Pioneer System Problem
My front driver door speaker and tweeter on my GS300 stopped working. I pulled the AMP out and no visible water on or around amp. All wires are plugged in on amp and speakers. Could i have just lost that channel on the amp? Thanks in advance for any suggestions!!!!!!
If you need some replacement speakers let me know because i have a full stock pioneer set just sitting around..
Excuse my ignorance on this subject but if the speaker went out/blown, wouldn't the tweeter still work? Also doesn't the amp have diferent channels for each speaker location? Do you have an amp for sale? My Sunroof water return tube was out of place in the trunk so i'm thinking maybe some water had gotten into the amp but doesn't explain why only one speaker is'nt working!! Thanks
Yeah it is not a blown speaker. That speaker must be disconnected either after the amp or before the amp I would guess.
PM me your email address and I'll send you the wiring diagram. You are just going to have to test each wire for that speaker and until you find the one that isn't doing the job.
At least with the wiring diagram you'll save a little time.
EDIT: OH DUH
1st things 1st. Take off the door panel and check the connectors on the door speaker to see if one came loose. The tweeter comes after that so it makes sense that they both go out together. They are wired together in series I'm pretty sure. No crossover or anything.
EDIT: OH DUH
DontHateSc
08-10-04 08:58 PM
