Parking Lights
Parking Lights
Can someone help me with where to tap into the parking lights on a '96 ES300? I want to install an aftermarket alarm and have the lights flash whem arming/disarming. Thanks in advance.
If you are installing an alarm yourself the parking light wire is just one of about 20 you will need to be tapping. I suggest a factory wiring manual for your car to find all the right ones.
The parking light feed is usually green by the way. Verify this with a multimeter as there are several green wires under the dash. The wiring manual will tell you where to find the right one.
Good luck
Good luck
Rollaboy
06-15-11 03:00 PM
raine
12-21-09 05:03 PM
raine
05-28-09 03:27 PM
