Nak vs. Pioneer????
Someone sent me an email stating that the head units are made by pioneer in the Nak systems.. and that the only nak items were the amp and speakers...is this true?
Would my nakamichi head unit work in a pioneer car set- up????????
Moderator - Electronics Forum
Nak head unit WILL NOT work in the Pioneer system. Wiring harness and plugs are COMPLETELY different. As for Pioneer making NAK head units, unlikely. They're both made to Denso physical specs (head unit size, types of plugs, etc) but the electronics are different.
Percy
Percy
RX 300 & 350Z Guru
Percy, you need an protogé? No not the car! There is so much car stereo information...just...can't....remember...all....head...going....explode!!!!
I try to figure it all out, there is more involved that I thought. I want to improve the bass in my RX - just going to leave the system stock otherwise. Sounds good. What do you think of that new "all in one" 10' subwoofer/amplfier unit. You know what I am talking about?
Nah...you'll do fine. 4 years of college and technical school will do that to you.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Percy
RX 300 & 350Z Guru
I saw this in a Crutchfield magazine - it is fairly new. It is an Infiniti - 200w - 10in. unit. Try this link to veiw it on crutchfield.com
http://www.crutchfield.com/cgi-bin/S...8BASSLIN&o=&a=
Here are some of the features - do not know what they all mean-----------------------
frequency response 20-120 Hz
low-pass crossover variable from 50-120 Hz at 12 dB per octave
amplifier power 200 watts RMS
speaker and line-level inputs
phase switch
bass boost adjusts from -6 dB to +3 dB at 40 Hz
25-amp fuse
auto turn-on with speaker-level inputs
remote turn-on lead (12V) required for use with RCA inputs
19' speaker-level input wires with plug-in harness included
14-1/2"W x 13-3/8"H x 9-7/8"D (vertical mount); 14-1/2"W x 9-1/2"H x 15-3/16"D (horizontal mount)
phase switch
25-amp fuse
lykdatyall
GS - 1st Gen (1993-1997)
07-19-07 10:57 PM
