PPI vs JL..help
Old 04-18-05, 02:35 PM
Percy
Moderator - Electronics Forum
Percy's Avatar
How about on a 12 volt system? Car off. Distortion levels with car running? THD? The MC4000M is rated for 1000w rms, at 12 volts. 0.005 percent distortion, from 20-20khz at BELOW rated power levels (where most of the grunge will occur...at the below rated power level). JL has a S/N ratio listing at the below rated power level, but NOT the THD. If they don't list, then it's usually at 1khz, which is usually the lowest number. I'd like to find out what the entire distortion spectrum (audio) looks like.
Even if they met all the criteria for their "specs", I would still have to take a look at the components that they're using. That way, I could look at a section and say "wow...they really beefed it up" or "that's where they were penny pinching".
Don't get me wrong...the JL looks like a fine amp. But, as Engin_ear mentions, it's more of a middle tier product...unless JL "really" outdid themselves and are trying to make a statement product...much like the Alpine F#1 Status or the Sony XES systems.
Percy
Originally Posted by StereoGuy
The JL amp also put out more power than advertised. The RMS ratings they publish are rated at 12 volts. With the car running and at 14.4 volts you output would is much higher.
Old 04-20-05, 02:52 AM
elclassico
elclassico's Avatar
Default ?
wouldnt you want to compare the ppi 1000w to the jl 1000w? i can say this i have a ppi 600w running 2 jl 12s in a sealed box pointing to the rear, and i myself and seriously considering purchasing the jl 1000 mono block. any one have any advice for me???
Old 04-22-05, 05:40 PM
StereoGuy
StereoGuy's Avatar
Which JL 12s do you have? Because, unless they are W6s or W7s the JL 1000/1 will be too much power.
Old 04-22-05, 06:12 PM
ILOVEGIRLS
ILOVEGIRLS's Avatar
side question.
which RCAs should i go with? the monster or rockford fosgate one?
Old 04-25-05, 07:31 AM
engin_ear
Everything in Moderation
engin_ear's Avatar
Originally Posted by ILOVEGIRLS
side question.
Generally the Monsters are better, but depends on how much you want to spend.
You pay more for the Monsters 'gimmicky' factor, but in general they're pretty decent. If you wanted to spend a ridiculous sum of money, there are many better cables out there, but they're only for us sicko audiophile types.
toy4life86
07-27-10 09:04 AM
Mr Soarer
11-30-07 09:13 PM
VIPsteelo
02-25-07 07:23 PM
chuckchung
10-17-03 10:15 AM
Quick Reply: PPI vs JL..help
