Low tweeter output 94 LS400 Nakamichi
Old 04-13-05, 07:13 AM
hardhat
hardhat's Avatar
Default Low tweeter output 94 LS400 Nakamichi
The stock nakamichi in my 94 LS400 sounds OK, but the tweeters have very low volume output. All of the other speakers seem fine. Does anyone know where the crossover is for the door speaker and the tweeter? I heard that both the tweeter and the door speaker were fed by same wire..... Is there a crossover in the door? Any idea what the problem may be (amp, crossover, bad tweeter) and where to begin troubleshooting? Or maybe the tweeters just don't put out very much.........'
Thanks
Larry Henderson
Old 06-20-05, 09:33 AM
chadr
chadr's Avatar
You ever get any replies offline on this one? Have the same issue now and am looking to get it fixed. Thanks.
Old 06-20-05, 02:16 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
I believe that's exactly the case...it's normal.
Old 06-23-05, 06:58 AM
chadr
chadr's Avatar
Actually both front driver side speakers have hardly any output. If I put the balance to the left and the fader to the front I can turn the volume all the way up and the music is hardly audible. Is it common for the amp to go bad? I will probably take the door apart soon to troubleshoot.
93 ls400 w/ Nakamichi
Chad
Old 06-23-05, 10:31 AM
93LS
93LS's Avatar
I have same setup (93 Ls400 + NAK )with worse ploblem.
Only rear right speaker is working with sub. rest of the three speakers and tweerer have very low out put. I don't know if it is amp or speakers gone bad. I want to keep stock headunit.
Please update me after you take the doorpanel off.
dose anyone know how to check if amp is working or not? with OHM meter?
93LS
mbz560
08-14-13 03:53 PM
hardhat
04-13-05 01:53 PM
Quick Reply: Low tweeter output 94 LS400 Nakamichi
