need help with wires from nakamichi unit
i just back my climate control and nak unit from LLS. the climate control works but there is a yellow and brown wire coming out from the nak unit and i do not know where to plug these wire to. i hook up everything and only the clmiate control lights up
btw, the climate control looks great
thanks LLS
![](https://www.clublexus.com/gallery/data/502/34547IMG_0342-med.jpg)
Keeper of the light
Yellow= switched ignition power. Grab either at the radio harness, or the cigg plug.
Black = ground.
Cigg plug center is positive (yellow), outside is negative (brown).
Or even easier than all, on the plug of the climate unit on the far right (looking at the front of the unit) grab the top far right wire for +12v switched (yellow) and the bottom far left for ground (brown).
All this is while looking forward at the front of the climate. Take a pic of the plug on the far right if confused and i'll draw on it for you
Black = ground.
