single vs. dual
Originally Posted by superpats
Can someone please explain to me the difference between single 4 ohm and dual 4 ohm?
Check out these links, they are very helpful:
http://www.jlaudio.com/tutorials/dvc/index.html
http://www.jlaudio.com/tutorials/wiring/index.html
I have two Diamond Audio dual 2 ohm subs wired series/parallel to run them at 2 ohms. The lower the impedence you run the subs [granted they're wired correctly], the harder the amp has to work, generally only run subs at 2 ohms or 1 ohm if the amp is made to handle it.
How's that for a first post.
Seize
07-19-07 03:24 AM
